Question about Pioneer SD-P4691K 50" Rear Projection Television
Pioneer stuck in stand by
I have a Pioneer SD P4681K. It is stuck in stand by mode and will not switch off of it. This happened after the power went out. It acts like it wants to switch over but never does.
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: pioneer sd-532hds. the red light is on but when
STK ICS 2 of them replace Both STK392-110 use 180s Mats Electronics has them $10.95 each
1-800-628-1118
Posted on Feb 25, 2010
Stuck in restart mode, keeps restarting and will only work once sd card is taken out
Did you download a new program or app before this happened? Try plugging sd card into a computer and delete any recent downloads and then try the card in your tablet again.
Jul 20, 2014 | Samsung P5100 Galaxy Tab 2 10.1 16gb...
Pioneer vsx c301
Can you explain a bit more? Generally speaking when this kind of component shows that behavior means that is stuck in protect mode because it has an internal fault, and furthermore in the power amp output section.
Sep 20, 2013 | Audio Players & Recorders
Pioneer sd-532hds. the red light is on but when
1-800-628-1118
Feb 25, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Dead no power.. checked main fuse, worked fine last night, went to turn it on today and nothing. its a sx-316 not sx-315, I say this because it tells me this is not a valid model#, but sx316 is printed on...
Check the resistance of the primary on the main power transformer, (with power off) should be 1-3 ohms. If open you need a new transformer.
If good turn it on and check for ac voltage (120v) there.
Nov 26, 2009 | Pioneer SX-315
Pioneer SD-P5181 will not power up
pioneer sd p5181 will not power up redlight on stand by works when i hit the power button makes a funny sound and then nothing anyone plz!!!! help thnks
Jul 11, 2009 | Pioneer Televison & Video
Power cuts off Pioneer SD-P50A5-K about 9 years old
Probably started as a bad solder connection but if it's blowing fuse FU106 now, you're probably in for a new set as that usually means your convergence IC's are bad along with a pair of darlington transistors that's mounted to the heatsink nearby. With the age of the set it may not be worth the trouble. If no fuses are blowing, you could still have a bad solder connection near the Switched Mode Power supply transformer. If that isn't it, you could have a bad High Voltage Block and you may end up having to replace the deflection board as well thank you Pioneer.
Feb 02, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer 610HD Turns on the will shut off to stand by after 1 second
You have problem in the power supply section of your set. You can obtain a service manual for 12.99 at the following link and they provide free help in diagnosing your problem. They will also email the manual to them if you click n the contact us link and request they email it.Hope this helps.
http://servicemanuals.vstore.ca/
Dec 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer P50A5-K goes to stand by mode
1) Pull chassis---remove power/convergence PCB==the one
with the large heatsink on it.
2) Remove solder from pins of four regulators on heatsink.
3)Clean board/pins w/ toothbrush & alcohol.
4)Re-solder, also solder both Stk's for prevent.
5)Re-assemble
Oct 10, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Stuck in Stand-by mode and will not turn on
try to soft reset the recievers by unplug for a while and replug and try power on , or hold up the rear reset butomn and press power at the szame time then release both
Apr 30, 2007 | Pioneer VSX-D912 Receiver
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Mar 28, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
