Question about Sony Cyber-shot DSC-W50 Digital Camera
Shutter speed Is there anyway to change the shutter speed, such as putting it on a bulb setting where i can just hold down the shutter and it will stay open?
Dfgb
Posted on Mar 01, 2008
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
Nov 10, 2012 | Canon Cameras
How to use the mc-dc2 how many buttons do i push to operate
There's only one button on the MC-DC2. Just plug it into the appropriate jack on the camera. You don't need to change any settings on the camera.
The button on the MC-DC2 now does exactly what the shutter release button on the camera does. The only exception is when the shutter speed is set to bulb. In this case the shutter remains open as long as the button is held down. There's a hold ring around the button on the remote; press the button and slide the ring in the direction of the arrow to hold the button down. Slide the ring in the other direction to close the shutter.
Mar 31, 2011 | Nikon MCDC2 Wired Remote Control for D90...
How do I change the shutter speed on a Nikon EM film SLR
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
Jun 29, 2010 | Nikon EM 35mm SLR Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
I mounted the Canon 580EX II to my Canon 5D Mark II. When I using Manual Mode, I can't set the shutter speed more faster then 1/200 sec. Is this problem normal/limitation of it?
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
May 11, 2010 | Canon Speedlite 580EX II TTL Flash
In manual mode cannot set shutter speed to
The "--" is the equivalent of the bulb setting with the remote control. The first press of the button opens the shutter and starts the exposure. Another press of the button closes the shutter and ends the exposure. This is so you don't have to hold the button down and risk a bird flying through the beam (and to conserve battery power).
Sep 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have the xsi and I am shooting in "M" and all of a sudden when I try to up my shutter speed pass 30 it shows "bulb" what do I do
The camera goes to "BULB" without any user action?
"BULB" is an option to manage the exposure time. The shutter will be open while you holding down the shutter button. So you can control the time,
Jun 27, 2009 | Canon EOS Rebel XSi Digital Camera
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
Shutter speed on my nikon d80 is to slow
Try CUSTOM SETTINGS MENU 31. (turn off EXP. delay mode).
Dec 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
89 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
