Philips XVents Model f12dt HDD type
Please can someone tell me what type of disk drive this laptop had. I need to remove it and put it in a disk caddy to recover some data. So I need to know which connector type the disk had.
Many Thanks
  • broketop Feb 29, 2008
    Commanderzod that's great. I can take it from there and get it sorted.
    Again thanks for your help.
  • 112 Answers
You will need an adapter such as the one shown in the link below.
http://www.bay-wolf.com/hddadapter.htm
Let me know what area you live in I will let you know where to get one from.
Posted on Feb 29, 2008
  • Geoff Champion
    Geoff Champion Feb 29, 2008
    thanks for the feedback broketop.
    Anything else let me know. ;-)
Hi. i have a problem in my laptop that there is a error with code 2000-0151 in dell inspiron 3520 window 7 home basic 64 bit. is there is any solution of the problem or i have to replace the hard disk ......
NO you do not need to reinstall win7 or buy a new hard disk
there are 3 fixes for your problem and I have all three you can have for free,
I'm assuming you are using another computer at the moment, so first download the program from this link,
How to Repair Errors in Windows 7
you can only use this if you can get your operating system to boot in any mode, if not download this disk (press the F8 key to get windows boot options and select mode)
https://www.filesanywhere.com/fs/v.aspx?v=8b6f63885d6571a970a0
and burn the iso to disk and boot from it and run scan disk on your hard drive, that may fix you problem right then, but if not, I have both Microsoft repair disks for win7 and can send you a link for that also, but I have to know which one you need,,,, there is one for 32bit and one for 64bit and you can only use the one that you have, So let me know
Mar 28, 2015 | Dell Computers & Internet
Lacie 250 gig HD will not show light on front when switched on, also no sound comes from it, it seems completly DEAD, this happened overnight, at end of night all was OK, in the morning it would not even...
the power regulator inside the external enclosure is probably dead the drive itself may still be intact,you can remove the dribe from the enclosure and run it as an internal drive if you have any free ports or you can buy a new enclosure for it and it should run fine.
Jul 01, 2011 | LaCie (301074) 80 GB Hard Drive
I have a IBM Thinkpad T20 Laptop. I need to install a new hard drive and I am not to sure how to do it. cAN YOU HELP?
you will need.
a philips or cross screw driver
the new HDD (hard drive)
and an instalation disk either XP, vista or linux.
uplug from the mains and remove the battery on the bottom of the comp you will see two large panels remove the you will find the hdd under one of them.
remove it the hdd will be held in a bracket type thing we call a caddy remove it and put it onto the new hdd insert it into the comp screw the panels back on replace the battery turn it over plug into the mains.
start the computer go into the BIOS push F2 i think go to boot and select the 1st boot from cd open the cd draw place in the cd close it push F10 it wil ask if you wish to save and exit push yes.
the computer will now shutdown and restart you will get a message in the top right screen push ant key to boot fron cd.
now folow the on screen prompts and ya done.
Oct 07, 2010 | Computers & Internet
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Screen does not come on . cylinder shaped light (by the power light and on/off light) is not lighting up.
          Sound like your Hard Disk drive is not starting up. They are normaly easy to replace, but i would try removing it & putting it into a hdd caddy, there is 2 types, 1 is the old IDe connection & the other is the Sata connection the bigger of the 2 is the IDE and has 2 lines of pins the Sata is normaly a female connector on the drive.
          If you can get hold of a caddy insert it & connect it to a freiends pc or laptop to see if it works, it saves buying a new hdd if its not faulty.
          Nov 08, 2009 | ASUS Eee 4G Notebook
          How to remove hard drive from acer 1360 aspire
          Detach the machine from the power supply.
          Turn the Acer Aspire 1360 over. Remove the battery.
          The hard disk caddy can be seen centrally located from the battery bay (it is shiny metal). There is a piece of clear plastic attached to the back end of the caddy.
          This is usually pushed back on itself under the plastic casing.
          There are two screws located in the casing around where the HDD is located.
          One is deepset and one is much nearer the surface.
          Remove the deepset screw and put aside for later.
          Get hold of the clear plastic strip attached to the HDD caddy (you may need a small screw driver to 'fish' it out). Gently pull the HDD caddy into the battery bay. It should come out quite easily, but you do need to apply consistent and mild force.
          Once you have the caddy out, you will notice that there are two screws holding the HDD in it. Remove them carefully.
          Remove the HDD from the caddy.
          Putting back together is the reverse of the above.
          Jul 22, 2009 | Computers & Internet
          I have a philips freevent laptop f-12dt
          F12DT Drivers list for Windows XP
          VGA : Mobil Intel(R) 915GM/GMS,910GML Express Chipset
          Version : 6.14.10.4020
          Date: 1/23/2005
          Audio : Realtek AC'97 Audio
          Version : 5.10.0.5830
          Date: 4/19/2005
          Modem : Motorola SM56 Data Fax Modem
          Version : 6.9.7.0
          Date: 12/22/2004
          CardReader : O2Micro OZ711MP1/MS1 MemoryCardBus Controller
          Version : 5.1.2600.0
          Date: 12/14/2004
          TouchPad : Elantech TouchPad
          Version : 5.0.2.1
          Date: 4/10/2005
          LAN : Realtek RTL8139/810x Famiy Fast Ethernet NIC
          Version : 5.621.304.2005
          Date : 8/18/2005
          INTEL Wireless : Intel(R) PRO/Wireless 2200BG Network Connection
          Version : 8.1.0.28
          Date: 8/24/2004
          go to http://www.twinhead.com.tw/tsd/Ftp/F12DT/F12DTdriver.htm
          and download WLAN.EXE for the the driver you want.
          Nov 18, 2008 | Computers & Internet
          Toshiba portege r100
          I believe if you download the pdf manual contained in the software here it may give you the answer as to what type of drive....
          http://www.manualnguide.com/manual-get/6459/
          Oct 17, 2008 | Toshiba Portege R100 Tablet PC
          Philips freeVents X50 Model f12dt
          here is a link to a few pages full of the battery you need:
          philips freevent x50 model f12dt battery
          hope that helps
          also call best buy they can surely assist you or special order one for you, they also have many references of other places you can go.
          May 15, 2008 | Computers & Internet
          2nd hdd
          both hard drives will need to be jumpered to a master and a slave or both have to be jumpered to cable select. normally the jumper setting are either on the label of the drives or are marked on the bottom of the drives near the jumper drives. if the setting are not shown find the drive type, model and capacity then do a google search for the drive "select the factory manufacture link" and search their site for the jumper setting of the type drive you have.
          BPCS
          Dec 05, 2007 | IBM ThinkPad T21 Notebook
          Computers & Internet Logo
          433 people viewed this question
          David Payne
          David Payne
