Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What to use in my washer?
I just brought a Whirlpool Cabrio, and I was wondering if I have to use hf washing detergent or can use my normal detergent till I run out? Thanks.
  • 5,911 Answers
If your washer is rated for HE detergent, then you're supposed to use HE detergent. The reason being is that HE detergent is concentrated and specifically made for washing machines that use LESS water than conventional washers. Regular detergents are formulated for machines that use about 35 gallons of water for a full wash tub. If you use that same soap in a washer that only uses 5 to 7 gallons of water, you are in affect putting a higher concentration of soap in your new washer. Originally, manufacturers of HE machines stated that you could use regular detergents as long as you cut back on the amount. They later retracted that statement, because regular detergents were damaging the HE washers. You should review your warranty closely. Most newer models now have a disclaimer that states if you use the wrong detergent in your new washer, the warranty becomes null and void. I hope this answers any questions you may have.
Posted on Feb 29, 2008
How to fix error message SD on our cabrio washer
Check the drain hose for kinks. Then check entire circuit: tub drain>drain hose filter>drain hose pump> drain hose for blocks. The particulars for your model would be in the owners manual or service maual.
Sep 06, 2014 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
5d code
5d is suds warning. The motor is being overworked from too much suds caused by improper measurements or detergent or both.
Cabrio service manual is on my service manual page
Run your washer without detergent a few times. Remember this washer uses less water than a normal washer it has 2 pumps. one recirculates a small amount of water over them clothes. You go adding in a regular amount of clothes and that washer fancy electronics gonna have a cow.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
When washing dark clothes in my Cabrio washer they are left with a white residue. I have been using Arm & Hammer HE detergent. Any suggestions? I am not using too much detergent. A friend uses...
Hello harnweys. Definitely switch to another brand of HE detergent, and always choose a liquid as opposed to a powder. Finally, be careful not to overload your machine, set the water level to a higher setting too! Joe
Thanks for choosing Fixya!
Jan 14, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How much laundry detergent to use in a cabrio washing machine? Someone gave me their washing machine but couldn't find the owner's manual.
1/4 cup dry detergent
12 capfuls liquid
Most people use way too much!
Doesn't matter you don't see much suds
its cleaning clothes.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer model GHW9200LW, THE CODE HF comes up ,tried the recommended fixes from the troubleshooting guide, but no luck
HF = High Fill
This can be caused by using non HE detergent in your front load. Put the washer in a cold rinse for a couple of cycles to clean the excess soap and try the cycle again using HE detergent. If the problem returns you may have a pressure switch or hose that will have to be replaced.
Aug 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW7600XW on the display screen is says sd and all the lights are blinking
The manual that came with the machine explains that the Sd error means "suds" and that means you are putting way too much detergent in, or aren't using HE detergent. If you keep doing this you're going to damage your machine. These washers are so water efficient, you only have to use about 1/4 to 1/3 the HE detergent the bottle recommends. Suds-lock has been the culprit behind many a HE washer death since their inception. Hope this helps.
Jul 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
177 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
