Question about Dishwashers
WATER NOT DRAINING OUT
Water is not draining out after running this just started.I've checked the drain going from house and shop-vaced the line and no clogs what could it be?
    Problem Solver:
  • 8 Answers
Turns out there's supposed to be a small amount of water left in at the end, to prevent the seals from drying out! I was stumped too after I cleaned everything out, checked the solenoid, and still had it. See:
http://www.appliance411.com/service/Myths_About_Appliances/Dishwashers/
Posted on Aug 01, 2009
    Sergeant:
  • 351 Answers
Check the drain spigot under the sink where the hose connects,or somthing could be stuck in the drain hose.
Posted on Feb 29, 2008
  • Ian Greenland Feb 29, 2008
    Make sure the pump is also working.
My lennox elite series cb29m-41-1p is leaking alot of water in the house with the air conditioner on. drain line to outside is clear
The condensation pan in the unit must have no cracks our brakes, and needs to be tilt down toward the condensation drain line, algae builds up clogs and must be cleared of clogs periodicaly
Aug 05, 2017 | Heating & Cooling
Tip
How to install a Water heater
Step one removal of the old one start's with turning the power source and water off to the water heater.
Once power and water is off connect a water hose to the drain on bottom of water heater to start draining. Open the drain and the hot side to a faucet to help water drain quicker.
Once drained and new heater their to go back in. Remove old one and reinstall new one.
Connect wires and water lines to new heater and turn water on first to heater once everything is connected.
Let water run til you get all the air out of tank and water running from hot side on all faucet's throughout house before turning power on to heater.
Once all air is out of tank and water flowing from all faucet's you can turn power on to new heater and about 30 to 40 minutes you should have hot water.
on Jul 13, 2010 | Plumbing
Water continuously drains and fills, and never gets particularly high
You will need to check you washer drain hose and make sure it is only inserted into your house drain pipe in the wall no deeper than 4-6 inches, alternately your house drain needs to be as high as the top of the washer lid. Be sure to secure your drain line from the washer to one of the water shut off fittings with a zip tie. You are most likely experiencing a siphon action because the washer hose is inserted too deep in the house drain. Pleazer Appliance...
Apr 17, 2014 | GE GTUP270EMWW Washer
Dishwasher not draining
It has a drain line that goes to a fitting on the garbage disposal or the sink drain if no disposal. It is held on with a hose clamp and can clog easily
Apr 06, 2014 | Frigidaire 18" Built-In Dishwasher
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
The water is not draining completely
Hello dmcgillvray1,
You aren't giving me much information to go on but I will point out some basic checks for you to do... First off, make sure you clean the filter screen where the water drains out of the dishwasher pan ( should be at some low point and needs to be free of any food byproducts that may restrict drainage... That said, if your dishwasher drains int a garbage disposal into your kitchen sink, make sure that it is clean of any garbage... (cycle it with water running to ensure there aren't any obstructions)... Those are the main culprets but you could have other issues... the pump itself is clogged, the lines feeding or exitting the pump are clooged or restricing flow... your house drain may be restrictive and limiting flow... Check the drain line that runs from the dishwasher to the drain itself to make sure it is not pinched off or clogged. I have used this technique a few times to verify the flow .... I have unhooked the dishwasher drain from the house drain ( normally under the sink and just by loosening a hose clamp... then using a large pail... started cycling the dishwasher ... when the dishwasher starts the drain cycle.. look for a very good flow of water.. if it is flowing good, then the problem is not the dishwasher and may be related to the house drain... Be careful not to over fill the bucket and it should fill up fairly quickly.. alternatively, you may be able to use a flashlight and look into the sink drain while the system is draining to look at flow... f it seems weak.. then you may have any one of the other problems mentioned previously.. Hope that helps...
Jan 30, 2010 | Kenmore Dishwashers
LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
GE Dishwasher not draining the water out
hi eddavid,
thank you for using fixya.
with regard to your issue, here is the possible cause. The check valve is worn and letting water back in the tub while it is draining there for not draining all the water out.
Can temporarily be repaired with a cork until i can get a new check valve.
You may also try to restart dishwasher with rinse only and as soon as it starts push reset and it will drain water out.
Going deeper into the appliance, the dishwasher has a rubber flapper style check valve located between the soil collection chamber and the drain line. These go bad and restrict the water from draining out. Also some models have a valve under screen in back called a piston valve if this has debris keeping it from opening and closing or is deteriorated you will need to change this also.Start washer let fill initiate pump out water should exit rapidy into drain if its slow check both items above
Hope this helps, if you have other question, please do not hesitate to let me know.
Regards,
voodoo
Apr 26, 2009 | GE Dishwashers
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Neptune draining problem
If the machine does not drain start checking the drain hose.
If the drain lines are not clogged, then you will need to access to the drain pump, and clean it , or replace it if it is not working.
Machine not draining can also be caused by a defective timer control, but this is rather unfrequent. If you already replaced pump, and lines are cleared, check that there is no water return from house drain pipes, and that wirings are OK.
Once you exclude all the rest, then you have the control board fault.
See also : It won't drain
This seller also have replacements and delivers worldwide.
Jul 10, 2008 | Maytag MAH6500 Neptune Front Loading...
Dishwashers Logo
100 people viewed this question
Top Dishwashers Experts
