FixYa.com
Tags:
Bosch BSG71360UC Bagged Canister Vacuum
Yanked the cord out of the vacuum (by 2 users)
posted by 1housewife on Feb 28, 2008
i pulled too hard on the cord and instead of retracting into the vacuum it came out, the ends are clean, and it looks like there is a lid that could possibly be the way into the compartment to reconnect the cord but how to open it?...or do i have to unscrew the vacuum? looks like it should be easy, any advice would be great, only technical diagrams i can find are patents in german
thank you
isabella
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 08, 2008
I have the exact same problem, and the situation is not resolved by the first answer. Actually, the "cord comes out clean" means that
1. The snap-on wire connectors (here female) separated and need to be re-connected.
2. When the back comes off (there are three allen-type screws) where the plug re-connects is not obvious.
I guess I may have to dig deeper!
Solution #1
posted on Feb 29, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 87%, 977 votes
Wasn't able to find any diagrams either, but there should be some screws to take out, and the top and bottom should separate. Don't let the cord reel spring unwind if it hasn't already done so. If it hasn't, one half of the reel should come aprt so you can re-attach the cord. then put the reel back together and let it wind the cord on the reel. If the spring is unwound and/or the reel wasn't made to come apart, then you will have to replace the cord reel asm.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Vacuums
How do i attach the
How do i attach the belt? And... Answer This...
Vacuums
the suction does not seem
the suction does not seem very... Answer This...
Vacuums
My Hoover Wind Tunnell Model
My Hoover Wind Tunnell Model... Answer This...
Vacuums
I need a diagram on
I need a diagram on how to... Answer This...
Vacuums
how do i use my
how do i use my kirby to clean... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
