Question about Maytag HYE3658AY Electric Dryer
Dryer ducting. I have two dryers in a condo laundry room. They are common and terminate to an outside wall. When the dryer farthest from the wall is used and a short time later someone attempts to use the dryer closest to the wall it does not work. After letting it sit for a period of time it will work again. I suspect that some of the exhaust is backing up into the dryer not in use and the condensation is causing the motherboard to short out. How can I stop this from happening?
Check all vent pipes and outside vent hood,thay should be keeped clean,and that the flex pipes are not kinked.Also a 4 " Y would be better than a T ,used to join them.Most dryers have a thrmo link,or a hi limit thermostat near the fan or in the outlet line.This is to prevent over heating. So poor venting,or bad lay out of the exust system may be the cause.If not the limit,or thrmo. be weak, and replacement is not that costly. Rob
Posted on Feb 29, 2008
Gas dryer wont stay lit
I'm assuming it "starts" to heat but then cuts off. Usually after the first minute of running you can open dryer door and feel heat but after awhile it doesn't heat.
1st, most common problem on a gas dryer not heating is "airflow" . They will "short-cycle" if there isn't near perfect airflow. Turn dryer on and go to outside exhaust vent. It should blow about as hard as you can blow into your hand. If any doubt disconnect dryer vent line from wall and let blow into your laundry room for one cycle and see if it is now working correctly. If it does work correctly when vent line is disconnected at wall you KNOW there is blockage somewhere in your vent line.
2nd, most common problem are gas coils. Easy to replace. 99% of all gas coils are the same so here is the part# (WE04X10020) (write it down.
Below is link where you can purchase appliance parts. Thanks for reading!
Appliance Parts
Feb 07, 2015 | Dryers
My maytag dryer takes almost 2 hours to dry 1 load of laundry
I would try cleaning out the dryer lent from the exhaust duct from the dryer and also the duct to the outside of the house. Lint also collects inside the dryer. It may worth cleaning out behind the lint filer through to the exhaust duct.
Regards
yourlawschool.com
Jul 08, 2011 | Maytag PYE2300AY Electric Dryer
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
The heat goes on temporarily and then shuts off
The most common problem is a clogged vent.
To do this, unplug your dryer and move the dryer out enough so you can get to the dryer duct easily. Most dryer ducting is flexible like a big slinky with a vinyl(older style no longer used) or metal type covering. There are some that are rigid as well.
Remove the duct from the dryer and where it attaches to the wall. Use a shop vac or house vac with attachments and insert through the wall and vacuum as much as you can. I use a shop vac since it has the blowing capability and I can check if air is coming out of the dryer vent located outside after I vacuumed it out. It is good to get confirmation that air is coming out of the vent. Check the dryer where the duct was attached and vacuum anything that is in there. Put everything back in reverse order and give it a whirl.
There are some homes,condos,and apts the have the hidden ducting go up the wall and through the roof. If this is the case, you will need to go on top of the roof and find the vent pipe. This pipe will have some sort of cap on it to let the hot air out but keep other elements out. Since you mentioned the heat goes on for a bit, have someone go on the roof (use caution) and have someone else turn on the dryer. The person on the roof can check the vent pipes with his hand for heat.
Nov 16, 2010 | Whirlpool Dryers
Miele T1515 electric dryer - overheats and laundry room feels like a sauna. What can I do about it?
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Sep 17, 2010 | Miele Dryers
Clothes aren't dry
Heating and not drying can be caused by 3 different things. I will address all three most common first
- Restricted air flow, usually a blocked vent. If the moisture from the laundry cannot get outside and fresh air in the dryer you will take extra long to dry. Be sure there is ventilation into the laundry room and more important make sure the vent is not kinked behind the dryer and that it is clean and allowing good air flow. You can go outside to where the vent terminates and feel the flow while it is running to check.
- Sensor has build up on it. Look in the dryer drum, inside on the back wall, inside on the front wall, somewhere depending on your model you will two strips of metal about the size of a pencil. Clean those with a little alcohol. Those are what sense the wetness of the clothes and control the cycle. If they get a build up residue on them they do not sense properly.
- The load is mixed, meaning you have some articles that absorb moisture like towels and some light garments that dry fast, the fast drying articles can fool the dryer into thinking the entire load is dry when the heavy articles are not.
Apr 23, 2010 | Frigidaire Electric Dryer
Getting a lot of condensation at wall where the dryer vent attaches, we have moved and the new house has a smaller laundry room. The first time we used the dryer I noticed a puddle of water, checked washer...
My suspicion is that the damper on the dryer vent is not completely closing, allowing the cold air to pass into the house. Also check to see if the vent hose is sealed to the vent with duct tape or steel tape.
Feb 22, 2010 | GE WSXH208A Front Load Washer
Our house is a split level and the laundry room is downstairs. The dryer vent hose goes up to meet the wall, where it goes outside. The vent doesn't take all the lint outside, most of it ends up in our...
Are there crackes in the hose and is it clamped on at the dryer outlet ?
Check also to see if it is pluged up or if the hose came off the connection to vent outside or also the vent flaps are sticking. If you by chance have solid tubes, wrap up the seams and connections with duct tape.
Oct 25, 2009 | Maytag Dryers
Takes the dryer over two hours to dry one load of laundry. It appears to be putting out hot air. When I stop it to check the clothes, the clothes are usually really warm yet still wet. This has been going...
You have a venting problem. Some makes of condo size dryers have a lint screen inside the drum at the back. Check and clean. If not then there might be a screen in the wall or the ceiling of the room the dryer is in. Trace the vent from the dryer to the wall or ceiling. There should be a vent fan in the ceiling. Try asking the condo property management if there is an exhaust fan in the wall that needs cleaning.
Jun 21, 2009 | Dryers
Fluff escaping from my Creda Simplicity Dryer T522VW
You don't say how much fluff is escaping, but some things to check are -
1) That the lint screen is fully seated into the top of the dryer vent
2) All the way to where it discharges the house, is clean and free of restriction
3) Check that the dryer door gasket and lint screen cover gasket's are in good condition and do not allow air leakage.
Make certain the flex duct leading from the back of the dryer is connected tightly to the dryer and the vent duct, and make sure the flex duct is not split or broken.
Jan 22, 2009 | Dryers
Maytag HYE3658AY Electric Dryer Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
