Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Daewoo Plasma dp-42sm
When I power on, the green light comes on but there is no picture.
  • 1 more comment
  • GRAV1 Mar 21, 2008
    SAME PROBLEM, GREEN LIGHT COMES ON BUT NO PICTURE
  • laurie123 Apr 03, 2008
    Have the same problem. Any answers?
  • Anonymous Apr 08, 2008
    I have the same problem
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Posted on Feb 13, 2010
  • bertgreer Sep 08, 2011
    what is ysus board ; is there a diagram
  • 3 Answers
It is because the power button was switched off on the t.v. when you turn the tv off by the button the tv, it sends it into some kind of standby, and it won't turn on from the remote, you just have to press the power button located on the lower left to turn on again
Posted on Mar 30, 2010
Hi, my Daewoo Plasma 42"
If the power light stays green then the current absorbed by the different boards appear to be normal. If that is the case then most likely you have a bad contact in the data cables or in the mainboard.
You will need to open the tv, inspect for damage and reseat all the components then (if that doesn't fixes it, you will need to extract the mainboard and check the soldering on the board and the status of the processor.
Jul 24, 2011 | Daewoo DSP4210GM 42 in. Plasma Television
I have a daewoo plasma tv model dp-42sm with no video after taking back cover off found the x- sustain pcb with a burnt ic chip labeled iu4. after removing defective pcb and powering up tv set power stays...
I have the Daewoo Plasma Digital Dream model dp-42sm and it had power but no picture and my dads tv expert friend looked at it said the ysus board was out. I got the part on ebay for 125 dollars with 12 dollar shipping and put it in myself very simple and the problem is fixed. Is this the same issue your having?
Dec 17, 2009 | Televison & Video
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo 42" Plasma dp-42sm lines in screen
The problem is you have a cold solder joint on a component on the flex harness. My son will show you have to fix it on YOUTUBE. Check it out!
http://www.youtube.com/watch?v=EFpXYnGZCU0
Jan 14, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Broken TV
Replace the y-main board and the upper and lower buffer boards. 300.00 from Sanyo. Install them your self or get someone technically minded to do it for you. It worked for me. It's been 6 months and the t.v. is still going strong.
Jan 04, 2009 | Televison & Video
Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
what way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
May 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Apr 13, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
DP42SM image very dull
What might be happening is the backlighting and or its circuitry is going bad.
Feb 11, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
772 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
