Question about Proton NT-3460 32" TV
Where do i plug dvd vcr player into tv there r 3 sets of red yellow&white
Top,middle or bottom group
Select an input set on the back (example "Video 2"), use the RCA cables to connect the video component player to the selected input. yellow is video signal, red & white are the audio. To view/listen, select with the remote using the button called "TV/Video" or something similar. Hit the button repeatedly until you are viewing the desired source.
Posted on Feb 19, 2009
Compatability with magnavox combo dvd and vcr
the back of the vcr/dvd player will have some rca plugs that are red,yellow,white,they will be labeled out putthe yellow is video,the red and white are left and right audio,the back of your tv should have the same thing,it should say input,get a rca cable with plugs on both ends and match the plugs to the colors,if you tv or dvd player,doesnt have these,then you will need to plug your cable box into the dvd player and run a coaxial from the dvd player and tv,use channel 3 or 4 on the dvd player and 3 or 4 on the tv
May 08, 2015 | Magnavox Televison & Video
CONNECTING DVD/VCR TO CABLE BOX & TV ETC
moz-screenshot.jpgHI-
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
Jun 30, 2008 | Philips Magnavox DVD/VCR Dual Player
I have trouble setting up my 50 inch T.V. It is connected to a VCR/DVD player recorder. I have a red, yellow, and white cable. Do I need anything more?
If possible use a AV SCART connection lead as you get audio & video! If you want to use the phono connection you need to connect all 3 red/white/yellow to the TV and the VCR/DVD! Red & white are audio, yellow video!
Dec 19, 2014 | Televison & Video
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
CONNECTION??
red goes to red, yellow goes to yellow, and white goes to white.
Jun 24, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up a d.v.d player to a vcr/tv combo?
RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
Sep 13, 2008 | Optical Coating Model 108 VHS VCR
HOW TO HOOK UP A VCR
yellow cord from vcr plug in the yellow input and then the yellow input on the tv
red cord from vcr plug in the red input and then the red input on the tv
white cord from vcr plug in the white input and then the white input on the tv
Jul 16, 2008 | Televison & Video
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Proton NT-3460 32" TV Logo
49 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
