Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Pico Fuzes? I finally got the STK 392-150 IC's installed this afternoon. The set worked for about 60 seconds before it went down. I have power to the set, but nothing works. When I had the board out to change the IC's I didn't find any pico fuzes or resistors that looked burnt, discolored, etc. I did get the tech manual for it, are the pico fuzes mounted on the same circuit board as the IC's?
    Genius:
  • 3,587 Answers
Usually...
sounds like something downstream is wreacking havoc on your control board, which it sounds like is history for the 2nd time
Posted on Feb 28, 2008
Will bad convergance ic's keep my Mitsubishi
If one of the two stk-392-570 chips has shorted it will blow a pico fuse on middle board and set will not come on.
Plug set in, turn on, when green power light goes out on the front of the set press and hold both the menu and input (device) buttons for at least five seconds and release both.
Power light will blink a two digit error code: if 2,2 it is a blown pico fuse and the chips also must be replaced. I have start to finish step by step instructions that are available if the customer selects me to answer in the new Marketplace here on Fixya.
see attached photo of chip and also part of middle board with the green pico fuses.
10_4_2011_6_10_21_pm.jpgchips look like this but will have 570 number on them.
SD TECH
Oct 04, 2011 | Mitsubishi Televison & Video
I replaced my convergence chips in my mitsubishi projection tv, the convergence is still out and does not move at all when I try, also there is still the bow tie - the top and bottom center pull in. Did i...
Hard to say what might be the problem, but I would be checking for the following:
a) verify all fuses (pico fuses) are not blown. They look like yellow, or green resistors typically and should be marked with some sort of "Fxxx" designator
b) Verify resistors around the STK chips are of the right value
c) Verify your soldering connections
d) It is possible the part you installed was defective. Verify you cannot move any color in any direction. (horizontal or vertical)
e) Try to verify if power is getting to the IC - if so, then likely an IC problem. If not, likely a fuse problem.
f) Finally get a schematic and verify the pinout from the STK chip to the red,blue, green connectors to ensure you did not accidently remove a surface mount resistor.
Mar 20, 2011 | Mitsubishi Televison & Video
I replaced the STK chips and one pico fuse that was blown on the input power board (the fuses and resistors near the STK chips are fine). I turn the power on, no screen and I get sound for 1 second, then...
A blink of 4 times is an error code that there is no vertical deflection. There may still be a problem with the + or - 15 volt supplies. This error is generate when the vertical deflection pulse is missing. there might be a problem with ic 8003 wich is the vertical drive ic. this chip generates a signal witch is detected by transistor q 8001 check pin 3 to see if you have 4 volt stop signal
Mar 07, 2011 | Sony KP-51WS500 51" Rear Projection...
Hello, I have a Mits. VS-60609 RPTV. All was good until the RED convergence jumped out (bows up at the edges). I went to the menu and tried to adjust the red..it will move left and right but not up and...
A common problem with convergence failure is either the STK IC chips and or the resistors. So yes, check for an open on the resistors to see if and possibly how many of the resistors need to be replaced. Good luck!
Nov 08, 2009 | Mitsubishi VS-60609 60" Rear Projection...
RED HORIZONTAL CONVERGENCE OUT.INSTALLED NEW STK 392 110.SAME PROBLEM
Please check does STK IC getting +22 and -22 volts supply to work properly, check pico fuses that might blew off / open, replace it and check.
Thanks.
Oct 29, 2009 | Toshiba 50H82 50" Rear Projection...
Mitsubishi WS-65611 IC's replaced
this set has a self diagnostic feature; when you turn it on and the green light goes out--push menu and device(or input) together for 5 seconds. the led for power should blink an error code. The most common is 2, pause and 2---this means something is shorted. If the set functioned before you changed the stk--you may have a new IC that is shorted--this IC is protected by two pico fuses usually marked as fao4 and fao5----they are about 3 inches behind the IC and are marked 5 a(they are green in color and do not look like fuses) also check all the 3.9 ohm blue resistors in front of the Ic--if any are white in the middle they are gone and the new IC got them. you did not remove the board? you tilted the entire chassis up to get at the IC? take a good look to make sure you did not pull any plugs loose---check for the error code first and let me know what it is. Best way to do this repair is to remove the entire board from the plastic frame---takes a little longer but is safer way to get it done. If one of the pico fuses is blown you will check it just like a regular fuse--an open fuse will suggest short and the set will shut down with 2, pause. 2 errror code.
Aug 18, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
