Question about Kenmore 47783 Electric Single Oven
Kenmore oven, mesh coil on oven door.
I would like to replace this in my oven, I don't know what it's called or if it's possible to replace it. My oven is only a year old but a casserole dish exploded in the oven and ripped this mesh thing to shreds. Now my oven is noisy when I turn it on to preheat. Can I replace this part and what is it called?
Thanks
  • 979 Answers
Yes you can replace it. It is a gasket that seals the oven when it is being used. It is heat resistant and vital to the operation of the oven. It is like running and A/C with the windows open.
Posted on Jan 29, 2009
I don't know the model # but its a kenmore oven and my daughter left her finger on the stop button too long and so the oven door automatically locked us out. I can't find the book for it
According to the eHow website,
"press and hold the stop/clear button for 3 seconds to unlock the door."
(it's the same to lock the door in the first place.)
According to the Just Answer website, either press and hold the stop/clear button for 3 seconds or 5 seconds, (A beep will sound. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked and the lock icon light has cleared.) or you have to press the button 3 times quickly.
Sep 25, 2012 | Kenmore Ovens
I want to change the door seal on the pyrolitic section of my double oven. its 15 years old and I believe I need to take off the door to achieve this. I also need to clean the glass inside. There is n
Should. Find few screws on the top and the sides of the door. Just unscrew them and see how the old one is that will give you a clue on how to replace it.
Jul 25, 2012 | Stoves Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door will not unlock
Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
MIchael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
My self-cleaning oven door will not latch. Displays error code dr
HI, This code will appear when there are serious issue that concern the integrity of the door latch mechanism. The control is unable to carry out the lock command, due to this mechanism failing, in this case. This damaged door latch assembly should be replaced asap. Once placed, the unit will preform correctly.
NOTE_ There is a possibility, that the door latch wires are loose. I would gain access to the door latch assembly, if possible, to inspect the wring that is linking the control to the actual door latch. Make sure the wiring harness is connected properly, and that the contacts are not damaged. If all is well, replace the door latch assembly
Nov 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven shows F2, door locked, keeps beeping
Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock
Jan 06, 2009 | Kenmore 42161 / 42169 Electric Single Oven
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47783 Electric Single Oven Logo
115 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
