Jvc pd35b50bu no brightness - Televison & Video
  • 44 Answers
The plasma gases in the television have already decayed. Plasma televisions last about 60,000 hours with optimal usage (4 hours per day of use) while in real life people really have their televisions on between 6-12 hours a day that would be about 5-6 years of prime usage of their plasma tv before the television start to dim out or gasses begin to decay.
Posted on Dec 31, 2008
Hitachi 46F510 different channels are different brightness and to get them viewable I have to run the brightness so high that you can not see any text at all. Also all white areas are blasting white bright. Edges of the tv also seem darker. I am connected to a cable system.
Posted on Nov 15, 2008
Can't get picture too get any brigther ,,have bright adjustment all the way to bright
There are several brightness adjustments on this TV. Download the manual from the following link. Set the size to a readable %. Then click "Edit", then "Find", and type "bright", then click "Next" repeatedly to review all your brightness options.
Jun 28, 2014 | JVC 37" Lcd Tv - Widescreen [lt-37e488]
JVC Modle HD-61FN97 2006 65 inch tv light went out replaced it now can not adj brightness
Aside from the customer controls you might be able to turn the screen controls up a bit to get more brightness, they are on a black block inside the set.
Nov 29, 2012 | JVC AV-65WP55 65" Rear Projection...
JVC PD42WV74 Display colors bright and almost fluorescent,dark areas & edges have a bright white edge, almost like the black level out??
colour wheel problem or use correction tool....eeprom colour wheel corrector can only be purchased through jvc. tech. support parts.
Oct 23, 2010 | Televison & Video
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Analog tv with poor color and brightness
probably tshe picture tube; time for new set
Mar 28, 2008 | JVC AV-27230 27" TV
JVC tv AV-27D304
Roger, if your contrast (sometimes called picture) and brightness controls are at max you can increase the tubes brightness by turning the "screen control" clockwise, be advised a little turn goes a long ways, don`t crank it too far or you will get retrace lines, you will have to remove the back from the set and follow the red wire down from the tube to the "flyback transformer" on the front of the flyback are 2 controls, focus and screen, do not move the focus control, this should fix your problem.
Nov 20, 2007 | JVC AV-48WP30 48" Rear Projection...
Flickering image/brightness up and down
the Iris in the optical block is stuck. Need new optical block. Temp fix turn unit upside down and tap bottom this will loosen the iris for a little time.
Sep 19, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC AV 270305 Brightness not Bright enough.
Yes you could look for the capacitor that is leaky, probably in the 200v line, or you could just open back and turn up G2 screen control on the Flyback. You have Screen and Focus on this black transformer with a long anode lead going to the picture tube of set. Becareful, High Voltage!
Sep 08, 2007 | JVC AV-27530 27" TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
