my pioneer xv htd330 5 disc dvd home theater system is stuck on progessive scan. i can't see the menu on my tv so i need a way to reset it back to factory settings.
From the manual: Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?. Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?. Press the front panel >/II button to set to interlace & switch the system back on.
Hi , I have a pioneer DV 285. While watching a movie the screen on my tv went blank, I looked at the...
(More)
Hi , I have a pioneer DV 285. While watching a movie the screen on my tv went blank, I looked at the dvd player and saw that there was no power on the dvd player, after searching a bit I found that I was sitting on the remote. I turned the power back on and the dvd player says it's loading for about 15 sec then the power goes off automatically. If I remove the disk the power always stays on but as soon as you put a disk into the dvd pkayer it powers down after 15 sec. Does anyone have any idea's ? Thanks Steve
Hi! My Pioneer DV-185 has spontaneously decided that I require closed captions, and I can't take...
(More)
Hi! My Pioneer DV-185 has spontaneously decided that I require closed captions, and I can't take them off. I also can't hear any sounds at all. No matter what I do to the settings, it won't go back to sound. It was working fine only five minutes before (I had to turn it off to answer the phone). Help, please?
Comment fait-on pour d?zoner ce type de DVD? Quel est le code et la proc?dure ? suivre ? Merci ?...
(More)
Comment fait-on pour d?zoner ce type de DVD? Quel est le code et la proc?dure ? suivre ? Merci ? tous How to uncode the Pioneer DV-285 S ? What is the code and what are the procedures ? Thank you all
