Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Uninstall roxio easy cd &dvd creator 6
Not in add/remove programs.
tried to delete folders - some will some wont.
upper & lower filterss deleted in registry.
still having problems with running other programs.
    Scholar:
  • 70 Answers
Use Registry Medic to clean up the registry mess
Posted on Mar 01, 2008
Refurbished Dell Optiplex GX280 with DVD/CD-RW Drive will not recognize blank CDs in order to burn music. I was told by the seller that I had to purchase burn software. (I also had to purchase CinePlayer...
The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
Jan 16, 2011 | Dell OptiPlex GX280 Desktop PC - Intel...
I have had trouble getting Roxio Creator 2010, Product SKU:POS-244000 to work properly. Since then I had tried to get the progran unistalled, but had some difficulty doing this as some part of he program...
hi sometimes parts of these programs stay in the system .making it difficult to do a clean install .go to computer and click/ open program files/ and check there are no traces left here if there is right click and delete folder.as well as this go to run/type:regedit/click go/in the registry( be careful what you delete here as this can affectyour system if you delete the wrong item) look for tracesof roxio easy media creator .if any right click the trace and press delete.finally you can go to cnet download and download a program for free named retrevo uninstaller.this will clear out every thing.hope this helps
Aug 28, 2010 | Roxio Easy Media Creator 10 Suite
Creater 7 will not record dvd or cds
If you are getting an error "No dvd/cd drive detected", you need to delete the roxio certificate.
Goto C:\program data\, find the roxio or sonic folder and delete it and restart the computer.
Regards,
Shrey
Jul 15, 2010 | Roxio Easy Media Creator 7
Cannot make mp3 files from cds
Don't bother using Roxio for this - use Windows Media Player 11.
1. Open Windows Media Player
2. Run the mouse over the "Rip" tab - a small aroow should appear underneath the word "Rip" - click on the arrow and a drop-down should appear.
3. Select - "Format" - change to "mp3"
4. Now insert your CD and press the Rip button - by default, Windows Media Player will store the mp3 files in the My Documents --> My Music folder
Now use Roxio to make a CD out of the Mp3 files
-Tha Mp3 Doctor
Mar 20, 2009 | Roxio Easy CD & DVD Creator 6...
Certificate File is missing in roxio
Just search your computer for any file hidden or not that starts with sarlicense9
I found a sarlicense9.dat, deleted it and now have no more issues.
I hope this helps.
-- Don Cote
Jan 10, 2009 | Computers & Internet
Error code 0641
Well, copying the contents of the CD to my hard drive did not do the trick.
However, I did find someone who mentioned something else to try, and this did work. The program is now successfully installed on my computer.
I did this:
Go to C: drive -> Windows folder -> System32 folder.
Look for a file called dsetup.dll in the System32 folder.
Rename the file to "dsetupOLD.dll" or delete the file.
Reinstall Easy VHS to DVD and follow the on-screen instructions.
After I renamed the dsetup.dll file, the program installed without a problem.
Thanks for the help and please spread the word around about this fix because this issue is very frustrating and time consuming.
Take care.
Aug 14, 2008 | Roxio Easy Media Creator 10 Suite
Media Center Receiver Service has encountered a problem and needs to close.
If you delete the information in the Control Panel and restart your computer, it will look for the driver by itself.
May 25, 2008 | Computers & Internet
Dead Driver for Easy CD Creator
Resolution WARNING: THIS PROCEDURE MIGHT CAUSE ANY OTHER ROXIO OR ADAPTEC SOFTWARE INSTALLED ON THE PC TO BECOME INOPERABLE. PLEASE UNINSTALL ANY OTHER ROXIO OR ADAPTEC SOFTWARE FIRST BEFORE ATTEMPTING THE LISTED PROCEDURE.
  1. Renaming the Take Two system file
    • Click on the Start button, and then select Search
    • Search your Local Hard Disks for the following file prtseqrd.sys
    • If you do not find this file, please go to step 2
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. prtseqrd.sys would be renamed to prtseqrd.rox)
      NOTE: If you decided to not finish this article at any point please rename this file back, you will be doing that later in this article. right hand corner of the window
  2. Remove Easy CD Creator 5 from Add/Remove Programs
    • Click on the Start button, then go to Setting and select the Control Panel
    • Double click on the Add/Remove Programs icon
    • Uninstall Adaptec Easy CD Creator 5, if prompted choose No to reboot the PC
    • Then click the X in the top right hand corner of the Window to close the control panel
  3. Removing Directories from your Hard Drive
    NOTE: All directories stated might not be found
    • Click on the Start button, then right click on the My Computer icon and then select Open
    • Double click on the icon for the Local Disk that the software was installed to
    • Double click on the Program Files folder
    • Locate the Roxio and Adaptec folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common Files folder, locate the Roxio Shared and Adaptec Shared folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common File\\InstallShield folder, locate the Engine and Iscript folders and rename them to Engine.ROX and Iscript.ROX. Once all the directories are remove right click on the "X" in the top right hand corner of the window to close it
  4. Rename additional files on your hard drive
    NOTE: All files in the list might not be found
    • Search your Local Hard Disks for the following files:
      *CDR4_2k.sys
      *CDR4_XP.sys
      *Cdr4dll.dll
      *Cdr4vsd.sys
      *Cdr4vsd.vxd
      *Cdral.dll
      *CDRALw2k.sys
      *Cdrtc.dll
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. cdrtc.dll would be renamed to cdrtc.rox)
    • After all files are searched for and renamed close the search window by clicking on the "X" in the top right hand corner of the window
    WARNING: THE NEXT STEPS INVOLVES EDITING YOUR SYSTEM REGISTRY. WE STRONGLY RECOMMEND YOU EXPORT YOUR REGISTRY BEFORE SYSTEM DAMAGE. WE RECOMMEND THAT IF YOU DO NOT FEEL COMFORTABLE EDITING YOUR REGISTRY THAT YOU SKIP THESE STEPS.
  5. To export a copy of your registry, please do the following:
    • Click on the Start button, then select Run
    • Type regedit and click the OK button
    • Locate and left click FILE in the upper left hand corner of the Registry Editor, then click on Export
    • Choose the Desktop as the location to save the file in, and name the file regbackup
    • Also ensure that under the Export Range section there is a dot beside All
    • Click on the Save button. Your registry should now be backed up to a file named regbackup.reg on your desktop.
  6. Remove the Roxio and Adaptec registry entries
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the + next to it.)
    • Expand the SOFTWARE Key
    • Locate the Roxio and Adaptec folders, right click each folder and click on Delete
    • If prompted to confirm the delete click the Yes button
    • Collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Expand the HKEY_CURRENT_USER key
    • Expand the SOFTWARE key
    • Locate the Roxio and Adaptec folders, right click on each folder and click on Delete
  7. Remove the UpperFilters and LowerFilters values:
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
    • Expand the SYSTEM Key
    • Expand the CurrentControlSet Key
    • Expand the Control Key
    • Expand the Class Key
    • Please look for a key containing the following string of letter and numbers: {4D36E965-E325-11CE-BFC1-08002BE10318}
    • High light this key by left clicking once on it
    • On the right hand side you are looking for UpperFilters and LowerFilters under the Name column, once you find these please delete them by right clicking on them and choosing delete
      Note: It will be easier to use the Registry editor in the future if you collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Please exit the registry by clicking on the "X"in the top right hand corner of the screen
  8. Renaming the Take Two system file
    • Search your Local Hard Disks for the following file prtseqrd.rox
    • If found, right click on the file and then click on rename. Change the file extension to SYS (i.e. prtseqrd.rox would be renamed to prtseqrd.sys)
  9. Shut down and Reboot the PC
    • Click on the Start button, then click on Shut Down
    • Choose the Restart option and click the OK button
    • Adaptec Easy CD Creator 5 should now be removed from your PC
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
Easy cd & dvd
ya bad program u should try to go to ther website download ther latse fixes patch for ther program ok if not use download nero 8 or 7 ok way coooler easy to make slide shows movies with music also windows phtoo story does it also free to download
Jan 26, 2008 | Roxio Easy CD & DVD Creator 6...
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... http://support.microsoft.com/kb/290301 Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Jun 19, 2007 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
75 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
