Question about Samsung SC-D353 Mini DV Digital Camcorder
Tape Eject I can not eject my cassette tape. I charged it for two days and I still can not eject the tape...I get R as an error - Any suggests
  • DeLa Man Mar 03, 2008
    Can any radio shack or video store assist?
  • 73 Answers
THE MOTOR IS BURNED UP. THIS WILL NEED REPAIR
Posted on Mar 02, 2008
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
Vhc tape is stuck in my video cassette recorder, it is a much older vcs, is their any way I could possibly that I can get it out without breaking the vcs?
Take ur finger senses all around the VCR the open flap door for sensors also pushes the eject button too as the same time,when the right sensors it hit ur finger the VHS tape will come out.
Mar 16, 2011 | Zenith Televison & Video
Cassette deck plays without cassette, makes clicking noise
The fault is that the reel drive of the deck is not picking up the tape and so to avoid the tape to entangle it rejects. Try to load a different cassete and see it this loads. If not you have a bad belt in your set. you will need to remove and change the belt. Also check for the reel drive to see if there is any slackness in taking up the reel. Since there are reel sensors that act when the reel pulse does not come on rotation of the reel, the set shifts to the other side and then ejects. Open and check this out and I am sure you can sort this out. Good day
Jul 10, 2010 | Sony DTC-ZE700 Dual Cassette Deck
Eject problem SOny TRV-110E
The vlatch to spring the basket (cassette holder) is easy to access on these. Many times the eject process will take place if the holder is released. After the door is removed the holder can be released by gentley raising the latch on the right side of the holder assembly. After the tape is out further checks can be made for damp drum or tension issues.
Jul 21, 2009 | Sony Handycam DCR-TRV460E Digital...
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Remove tape error message
I used my hairdryer to blow dust out of the cassette compartment. It worked for me.
May 05, 2009 | Canon Optura 20 Mini DV Digital Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
341 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
