Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony Trinitron Color TV - KV-27TS27 circa 1991
When I turn on the TV, lines appear and the colours look like they are bleeding. I have to turn the set on and off before the color becomes normal.
Any assistance is appreciated.
RR
    Champion:
  • 252 Answers
There,s a lose connection on vertical section of your tv. to resolve that to \resolder the vertical section but be careful of short circuit t may damage your system
Posted on Oct 19, 2008
My picture has broken into colour ghosting (it looks like a 3d picture without the glasses on). I'm guessing that this might be the failure of one of the colour bulbs. The wavey colour bands that I see are...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2011 | Hitachi 57F500 57" Rear Projection...
In My sansui k2k21 flat tv showing red colour more please tell me will i replace the eht or crt
you do not have a CRT in your flat panel set.. What you might have is your color setting to high causing the bleed or your
T-con board is bad , but first turn down your color if that does not do it have a tech replace your
T-con board
Nov 19, 2009 | Sansui HDLCD3200 TV
Colour lines on samsung tv top side concave
  • Unplug your TV.
  • Leave it unplugged for a minute or two.
  • Plug the TV back in and turn it on.
  • Dec 06, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
    42" philips plasma flat panel television
    same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
    Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
    Colour problem
    I have default settings I normally use for most sets before I begin any kind of alingment. Contrast: 90% Brightness: 45% Color: 45% Tint: 50% If the brightness is to high or the contrast to low the color is off. Check your connections, there probably OK, but, it never hurts. If the settings don't help call a local authorized servicer in your area. Hope this helps.
    Jun 23, 2007 | LG 42PX3DCV 42 in. Plasma EDTV
    Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
    your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
    Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
    Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
    792 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
