Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Side by side Kenmore fridge
Fridge side sometimes stops getting cold but the freeze side seems fine... nice and cold. Any thoughts
    Problem Solver:
  • 4 Answers
Possible fan problem..
Posted on Apr 04, 2008
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
The freezer seems fine but the other side is not very cool.
I had the same problem w/mine, Found out it was the timer. There is a timer on most fridge's that turn on a defrost lamp inside your fridge. That is why all fridgs are frostless now. They still freeze up, but a lamp will defrost them automaticly. When the coils freeze up, they wont cool the fridge side & but will still cool the freezer side. generally the timer is where the controls are, behind the cover.
Mar 31, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Fridge not cold freezer is fine
Your defrost element is faulty, this is attached to the bottom of the freezer coils and also has a defrost limiting thermodisc which should be replaced at the same time. You are getting a freeze up and therefore no air circulation. Also check that the fanmotor is ok.
Mar 04, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frezzer is fine but fridge is warm
See if cold air is coming out of the air diffuser top-back freezer side of fridge. A common problem is a bad air diffuser assembly. Sometimes it may freeze closed and break when it tries to cycle. The freezer usually works fine.
Aug 05, 2007 | Kenmore 53602 / 53604 / 53609 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
