Question about Motorola Mobility RAZR V3m Cellular Phone
Razr V3 back light will not go out
The back light on the main screen will not go out when the flip is closed and occasionally when it is reopened will not display wallpaper.
  • winderups Mar 05, 2008
    Help the stupid. What am I looking for?
  • HBennett07 Mar 08, 2008
    I am having the same problem with my phone!
    President:
  • 1,017 Answers
Try an update of the phone software. Start here:
http://direct.motorola.com/hellomoto/index.htm
Posted on Mar 04, 2008
Black screen on RAZR V3
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 02, 2010 | Motorola Mobility RAZR V3
V3 outer screen
There's a tiny magnet in the top of the flip, near the hinge.. try taking a small magnet and hold it over the keypad near the hinge, and see if it doesn't think it's closed, if that magnet didn't get put back in the flip, then the phone won't know it's closed.
good luck!
Oct 26, 2007 | Motorola Mobility RAZR V3i Cellular Phone
My screen won't light up, phone seems to still work.
the fault is not from the screen but from the flex that connects the screen to the phone's main board.
This is common with flip and slide phones. The flex gets weaker as it is being opened and closed frequently.
So you need to change the flex for your screen to light up again.
I wish you the best of luck.
Jan 13, 2010 | Motorola Mobility RAZR V3
My screen just went blank
If u have a Razor (As shown in the picture), If the mini Screen Works(When you close the phone) then then make sure the push down button((Turns off the main screen when you flip the phone closed) is not pushed down while the phone is open.
Hope this helps.
Jul 01, 2009 | Motorola Mobility RAZR V3
Motorola razr v3
First take the phone to a mobile service center and have them replaced your ear piece as well as the flexcable to correct these issues.
Oct 22, 2008 | Motorola Mobility RAZR V3
Loose "flip" (display) on a Razr v3. How can I tighten it..??
You may need a new Flip assembly.
The version might depend on your model of V3 (RAZR)
May 22, 2008 | Motorola Mobility RAZR V3
V3 never registers when I close it, battery is being wasted!
You forgot to replace a small magnet that goes in the upper right corner of the cover (when closed) next to the screen. Try to put a magnet in the circular hole.
Apr 24, 2008 | Motorola Mobility RAZR V3
No date display
yep i have the same problem too. no date display. it displays the date on the outer screen when i flip the phone shut. but not on the main screen when it is open.
Jun 18, 2007 | Motorola Mobility RAZR V3
Razr v3
It sounds like there is a loose connection in there or a button is stuck. There is a magnet that lets the phone know if it is open. It is located in the lower righthand portion of screen and the sensor is located in the upper righthand corner of the keypad. Get a magnet and play with it. What happened to it? Is it still under warranty? If not crack it open and see. There are numerous manuals online for the razrs. Only for the brave or stupid, but it just a phone.
May 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
126 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
