Back to:
Tags:
Panasonic DP190 All-In-One Laser Printer
DP-190 Network Printer
posted by eco-tech on Feb 28, 2008
Trying to set the Panasonic DP-190 as Network Printer. I have NO domain and NO dhcp, it is Per to Per. Printer is connected via Ethernet to the HUB, and the Internal Local IP is already set in the Printer (192.168.1.86 for example) . but when I try to create the IP port the local stations the printer is not found. I dont find any print server software in the CD that comes with the printer, so somebody have any idea? Thanks!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 30, 2008
Not Rated (0)
johncall
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I succeeded in printing via network to the Panasonic Workio DP-190.  Here is a brief summary of what needed to be done...
* HP laptop w/ Windows XP SP2 installed * requires LPR support via "Print Services for Unix" to be installed from Windows Components (http://technet.microsoft.com/en-us/library/bb457002.aspx) * Installed using GDI printer driver (http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/list.html)
During the GDI installation I choose a 'Network printer' and the printer was already setup for proper IP addressing, etc...
I created a new printer port of type LPR, doing so required me to input the printer's IP address and a queue name -- the queue name was left blank.
Hope this helps, John
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on DP-190 Network Printer:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
Canon MP830 message re: waste tank full. How do I get to...
Toner was out....a lot of faxes came in 100% memory full...
I have downloded the drivers for my Panasonic DP180 but it...
Our office printer is saying that it has a misfed paper,...
every time when fax come in, can hear the phone ring but...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
