Question about HP DeskJet 1280 InkJet Printer
Incorrect "Out of Paper" error
My 1280 keeps giving an out of paper message long before the stack is gone (about 20 sheets to go). The last 20 sheets in my printer have been sat there since I bought it about 18 months ago!!!! Also have problems clearing print queue when there is some sort of error with a document. Have managed this with assistance from the net, but shouldn't they have sorted out these problems - seems no updated drivers since I acquired.
IN THE BACK OF THE PRINTER IS A BOX WITH A LOCK SIMBOL FOR MANUAL FEED PUT HIM BETTER
Posted on Mar 01, 2008
Remove paper from sheet feed when no paper loaded
It is possible that the genuine replacement HP sensor is defective.
Jan 09, 2014 | HP DESIGNJET T770 Printer
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Hp color LaserJet 3700 jams 70# uncoated letterhead stock
    Hi manitou344:
    Here is some info that might help you.
    Table 1-8. Tray 1 paper sizes1
    Media Dimensions Weight or thickness Capacity
    Minimum size paper 76 by 127 mm
    (3 by 5 in)
    60 to 163 g/m2
    (16 to 43 lb bond)
    100 sheets
    (75 g/m2; 20 lb bond)
    Maximum size paper 216 by 356 mm
    (8.5 by 14 in)
    60 to 163 g/m2
    (16 to 43 lb bond)
    100 sheets
    Minimum size glossy
    paper
    76 by 127 mm
    (3 by 5 in)
    75 to 120 g/m2
    (20 to 32 lb bond)
    Maximum stack
    height: 12 mm (0.47 in)
    Maximum size glossy
    paper
    216 by 356 mm
    (8.5 by 14 in)
    75 to 120 g/m2
    (20 to 32 lb bond)
    Maximum stack
    Minimum size
    transparencies2
    76 by 127 mm
    (3 by 5 in)
    0.12 to 0.13 mm thick
    (4.7 to 5 mils thick)
    50 sheets
    Maximum size
    transparencies2
    216 by 356 mm
    (8.5 by 14 in)
    50 sheets
    Minimum size
    envelopes
    76 by 127 mm
    (3 by 5 in)
    60 to 90 g/m2
    (16 to 24 lb bond)
    10 sheets
    Maximum size
    envelopes
    216 by 356 mm
    (8.5 by 14 in)
    60 to 90 g/m2
    (16 to 24 lb bond)
    10 sheets
    Minimum size label 76 by 127 mm
    (3 by 5 in)
    75 to 163 g/m2
    (20 to 43 lb bond)
    50 sheets
    Maximum size label 216 by 356 mm
    (8.5 by 14 in)
    75 to 163 g/m2
    (20 to 43 lb bond)
    50 sheets
    Minimum size
    cardstock
    76 by 127 mm
    (3 by 5 in)
    135 to 216 g/m2
    (43 to 43 lb bond)
    50 sheets
    Maximum size
    cardstock
    216 by 356 mm
    (8.5 by 14 in)
    135 to 216 g/m2
    (43 to 43 lb bond)
    50 sheets
    This printer can
    detect transparencies that were not designed for use with HP Color LaserJet printers.
    Jun 30, 2009 | HP Office Equipment & Supplies
    False empty paper tray message
    Dude,
    If an“Out of Paper” message is shown on your computer and your printer cannot pick up paper, then follow the steps below (in the order) to resolve the problem.
    Step 1:Checking the media and print settings:
    1. Remove power cord when the printer is ON, wait a while and then plug it back.
    2. Turn the printer ON.
    3. Place a Paper, which is not ripped, dusty, wrinkled, or bent.
    4. Place the papers of same size.
    5. Tap the stack of the paper.
    6. Verify the stack of paper between 10 to 25 sheets.
    7. Insert the stack of papers into the printer.
    8. Set the paper settings in the print driver.
      • Open a Document in the application, which has to be printed.
      • Click File > Print > Properties > Paper/ Quality tab.
      • In the Size Drop down menu, Select the Size of Paper.
      • In the Type Drop down menu, select Type of Paper.
      • Click OK.
    9. In the Print Dialog box, click OK to print .
    10. Try printing again.
      Note: If this step resolved your problem and you want to print on another media, change the paper in the unit, repeat steps 2 to 7 above for the new media.
    this will solve your problem
    Dec 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
    STACK BYPASS option causes LOAD PAPER message & no print
    1-did you change to bypass instead of trays in the menu?
    2-the sensor (black lever in the bypass that triggers the sensor) is missing or bad
    Oct 09, 2008 | Canon imageRUNNER 400S Copier
    Epson 1280 Will Not Take Paper through to print?
    Follow the instructions below in an attempt to resolve the issue you are experiencing.
    1) Turn off the printer and remove all paper from the paper tray.
    2) With the printer off, check for any obstructions such as torn paper or foreign objects.
    3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
    4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
    5) Attempt printing.
    Apr 19, 2008 | Epson Stylus Photo 1280 InkJet Printer
    Printing
    Dear jamin4volks;
    As per this excerpt from the Oki B4350 User manual:
    "FACE UP AND FACE DOWN PRINTING
    For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
    For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
    Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
    This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
    Hope this helps;
    Frank
    Apr 18, 2008 | OKI B4350 Laser Printer
    HP DeskJet 1280 InkJet Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
