There are several caps on the power supply that fail on this unit causing this problem. To get to this power supply is a major disassembly and you will need a qualifed tech to do this. The main two caps are the 3300 uf caps.
You connected white wire and red wire together. No harm done. ez to fix. Woods 59018 is single pole timer. Copy following link to see step-step for wiring single-pole timer: http://waterheatertimer.org/How-to-wire-timers.html Add a comment as needed
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
Setting the ON time (Example: AM 10:15). 1. Press the TIMER button on the Unit for more than two seconds. The Timer indicator lights up and the hour digit of the current ON time blinks on the display. • When the clock is not set, “CLOCK” and “ADJUST” appear alternately on the display. Set the clock first. Press the ¢ or 4 button on the Unit to set the hour you want the Unit to come on. Pressing the ¢ button moves the time forwards and pressing the 4 button moves it backwards. Hold down the button to move the time rapidly. 2. Press the TIMER button. The minute digits of the ON time blink on the display. Set the minute you want the Unit to come on, using the ¢ or 4 button. 2 Setting the OFF time (Example: PM 1:30). 1. Press the TIMER button. The hour digit of the OFF time blinks on the display. (The same time as the ON time will be automatically set.) Set the hour you want the Unit to be turned off, using the ¢ or 4 button. 2. Press the TIMER button. The minute digits of the OFF time blink on the display Set the minute you want the Unit to be turned off, using the ¢ and 4 buttons. 3 Selecting the music source. 1. Press the TIMER button. The “TUNER” or “CD” blinks on the display. 2. Press the ¢ or 4 button to select the music source you want to listen to. The display changes as shown below. TUNERôCDô(back to the beginning) 4 Setting the volume level. 1. Press the TIMER button. The current volume setting blinks on the display. 2. Press the ¢ or 4 button to select the volume level. -- :The current volume level will be used. 0 to 50 :When the timer is turned on, the Volume will be automatically set to the selected level. 5 Press the TIMER button. The timer setting is completed and the display returns to the display before you set the Timer. The Timer indicator remains lit. 6 Before turning off the System, prepare the music source selected in step 3. TUNER: Tune in to the desired station. CD: Insert a CD. (Playback will start from the first track at Timer on.) 7 Press the % button to turn off the System. In standby mode, you can see the Timer indicator ( ) on the display. • When the timer turns on, the Timer indicator starts blinking and the prepared source in step 6 will be played. To cancel the timer, press the TIMER button. The Timer indicator ( ) goes out on the display. To re-activate the cancelled timer, press the TIMER button to light the Timer indicator ( ). At this time, you can see the current timer settings. Each setting appears on the display for two seconds in the order of ON time, OFF time, music source and volume. To change the timer setting, repeat the setting procedure from the beginning.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions. http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
