Question about Tomtom GO 300 GPS Receiver
Tom tom one battery change
How do you remove the cover of the tt1 v2 so as to fit new battery. cheers.
I too dropped my tom tom go 300. It appears the battery was disloged as it will only work if attached to another power source; AC Adapter or cigarette plug. Does anyone know how to open the case to check on the battery?
Posted on Nov 03, 2008
MY TOM TOM 510 WILL NO CHARGE UP CAN U TELL ME IF THE BATTERY IS NEEDING CHANGED
Posted on Oct 22, 2008
Replace battery on my om tom go 300
original battery ICR18650-24 sometimes marked Type VF5 or similar. Battery
  • Remove the front screen surround -- just gently prying does the trick. (Img 1)
  • Undo four T8 screws holding internal works to outside body. (Img 2)
  • Remove internal works from body. There is a cover/clip for the bottom panel (where the car mount connects) that just falls out once the insides come out -- pay attention to how it fits in, so that it can be replaced on reassembly.
  • At the base you will see silver foil covering (Img 5), the foil needs to be peeled back in places, but I left as much of it on as possible (unlike the images I'm referencing).
  • Peel back the foil around the speaker, and remove the two T8 screws, being careful not to disconnect the speaker -- it only needs to be moved aside. (Img 6)
  • Continue peeling back the foil down to the circuit board, but leave the board itself covered. You will need to manipulate, but not remove, the thin metal "cage" that is shown removed and behind the unit in Img 11.
  • On the still-covered circuit board there are four T6 screws that need to be removed. These screws can be seen in Image 11 -- one on either edge at the bottom, and one on either side of the car mount in the middle top.
  • With the foil loosened and the screws removed, manipulate the metal "cage" to expose the two T6 screws securing the black plastic battery holder (plainly visible in Img 11). Be very careful not to accidentally disconnect any of the wires/cables.
  • Remove the battery holder, unclip the old battery, replace with new one, and reassemble. (Img 16)
  • The unit should be able to power up as soon as the new battery is connected, so I tested it a few times as I reassembled, just to be sure I hadn't jostled anything loose as I went along.
Sep 17, 2009 | Tomtom GO 300 GPS Receiver
Tom Tom One won't charge up
THE AVERAGE BATTERY LIFE FOR THESE IS 2 YEARS, YOU ARE WELL PAST THAT, U NEED A NEW BATTERY.
Aug 31, 2009 | Tomtom ONE GPS Receiver
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom rider 1 not charging when on bike
TOMTOM are VERY aware of this problem. but deny it is an issue!
I had the same problem, they sent me a new shoe after weeks of emails. I told them that the shoe is not the problem, it's the connector on the back of the TT1. Because of the springloaded pins fitted to the shoe and the poor quality connectors on the TT the normal vibration on a motorcycle causes the pins to wear holes in the connectors on the TT causing intermittant connection.
As the cost of repairing or replacing these connectors is very high and there are a large number of units that would require this repair TT are ignoring it.
I'm now looking at a way of bypassing the connector altogether.
A temporary solution appears to be to smear the contacts on the back of the rider with a little petroleum grease or WD40 - seems to work for a couple of weeks at a time.
Sep 01, 2008 | Tomtom RIDER GPS Devices
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 300
you have te release the front cover. Then you see a couple of torx screws. Release them and the tomtom is open. You can change the battery
Jan 04, 2008 | Tomtom GO 300 GPS Receiver
Tom tom one switch on
with tomtom turned on, remove SD card and press RESET, turn off tomtom and insert SD card and start tomtom, problem solved :))
Dec 06, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
2,495 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
