Everytime I try and shoot a video the audio doesnt work when I upload to my computerEverytime I try and shoot a video the audio doesnt work when I upload to my computer
You can't post conmments that contain an email address.
Chipmunk
Sounds From Computer Speakers My
wife had an interesting issue over the weekend. Anything she played on
her computer came through the speakers sounding like chipmunks. You've
heard the Alvin and the Chipmunks albums, that's what it sounded like.
It didnt matter if it was a Windows sound (wav file), and MP3, a WMV,
or any other multimedia. Everything sounded like a chipmunk was playing
it. The sounds were played too fast and too high pitched.
Her
computer is an Acer with a Realtek sound card built into the
motherboard. It has the Realtek HD Audio Manager built into it and I
thought at first that something had changed with the audio settings.
However, after examining the audio utility and choosing to reset the
environment back to its defaults the chipmunk sound was still present.
he
Realtek Manager also has an option for Karaoke Mode, which basically
removes the voice track when playing a song. Changing this feature had
no effect on the system.
Uninstalling and Reinstalling the
Sound Card
The
only way I found to truly fix the issue was to uninstall and reinstall
the Sound Card. Follow the directions below to accomplish this.
1) Open Device Manager by Right-clicking on My Computer and choosing
Properties. Then click on Device Manager
2)
Under the Sound, Video, and Game Controllers section, Right-click on
Realtek High Definition Audio and then click on Uninstall.
3) Close the Device Manager and Reboot your computer
4)
After the computer reboots, allow it to automatically find the Realtek
audio device on its own and reinstall the drivers. You may be required
to reboot the computer a second time after the drivers for the sound
card load.
5) Test the sound card by playing an MP3, WAV, WMA, or other sound or
by watching a video online.
The
problem should be fixed. If for some reason, you are still experiencing
a chipmunk-like sound coming from your speakers, visit the sound card
manufacturers website and download and install new drivers for the
sound card.
make sure when you take a video you adjust the volume first so then you will have the sound you want..press the mode button to access in audio mode with the arrow buttons then press ok button. in the audio mode to selct the voice recoding file you want to play press ok button to start playback of the voice recording file thru vivicam speaker..good luck hope this give you an idea somewhat..
It most likely IS the .mov file. I recommend buying quicktime pro, $20, which will allow you to convert the file, or if you get the free version of quicktime, and the video and audio play fine with it, You can use a screen recorder and turn off the "record external Mic" mode, and turn ON "Record Computer Audio" Once you're done converting (or recording) You can go ahead and edit, Hoped this helped- sincerely:
animation508 (youtub username)
There is no sound carrier on an S video connection. It's Video only. use the AV left and right cables for the sound. It is normal not to monitor audio when capturing.
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual.
Audio Dubbing
* The AUDIO DUBBING function only works in PLAYER Mode.
* You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound.
* Use the internal and external microphones or other audio equipment.
* The original sound will not be erased.
Dubbing sound
1. Set the camcorder to PLAYER mode.
* If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder.
* When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder.
- Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button.
- Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN.
2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed.
3. Press the (PLAY/STILL) button to pause the scene.
4. Press the A.DUB button on the Remote Control.
* A.DUB will be displayed on the LCD.
* The camcorder is in a ready-to-dub state for dubbing.
5. Press the (PLAY/STILL) button to start dubbing.
* Press the (STOP) button to stop the dubbing.
Notes:
* You can not use the audio dubbing function while playing a write protected video tape.
* When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record.
* You cannot dub sound on a pre-recorded tape in LP or 16 bit mode.
Dubbed audio Playback
1. Insert the dubbed tape and press MENU button.
2. Turn the MENU DIAL to highlight A/V.
3. Press the ENTER button to enter the sub-menu.
4. Use the MENU DIAL to select AUDIO SELECT from the submenu.
5. Press the ENTER button to enter the sub-menu.
6. Using the MENU DIAL, select the AUDIO playback channel.
Press the ENTER button to confirm the audio playback channel.
* SOUND1 : play the original sound.
* SOUND2 : play the dubbed sound.
* MIX(1+2) : play back SOUND1 and 2 equally mixed.
7. To exit, press the MENU button.
8. Press the (PLAY/STILL) button to playback the dubbed tape.
Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
