Question about Car Audio & Video
Handa prelude 93
Car is geten petrol and has a spark just wont start
  • 2,039 Answers
If you have gaz and sparks the car should starts if it doesnt start the timing belt is probably jump to check if timing belt is diffectif you have to put cylinder 1 in compression that mean piston all the way up you look at the timing mark it should at 0 remove the distributor cao the rotor should be on cylinder 1 but im sure its not gonna on number1 check it out let me no you need to know mechanic with does intruction our gonna be ok
thanks for using fixya
Posted on Feb 29, 2008
Won t start
double anon posted. and this time no year.
ah but you cleaned it and now it dont run
well we can not guess all the things you did wrong. or forgot.
if you used a pressure washer , (bad that) then you have water
were water dont belong. think so?????
or put back wires wrong or for got to connect , some connectors.
if UNSTATED engine has spark wells.
they are full of water now and spark just hates to be underwater.
93 swift. what engine.??????????????????????
1.3 L M13A I4 (petrol)
1.5 L M15A I4 (petrol)
1.2 L K12B I4 (petrol)
1.4 L K14B I4 (petrol)
1.6 L M16A I4 (petrol)
1.3 L Multijet I4 (diesel)
Jun 27, 2014 | Suzuki Swift Cars & Trucks
My 93 prelude won't start i change the fuel pump i check my fuses so what now i need help
You will have to see if your getting spark and fuel. If your getting both it should be starting either timing or injector pulse isn't working maybe. If your not getting spark, you will need to check your ignition system. If your still not getting fuel then you have a relay or maybe a computer problem. This isn't exact but a short list of what to check so you can reply with more information.
Aug 05, 2011 | 1993 Honda Prelude
How to find the brain in a 1987 handa prelude
under pas side kick panel is the ecu aka your "brain"
Sep 11, 2010 | 1987 Honda Prelude
Ive changed the spark plugs in my honda prelude and now the car wont start
does it even crank? put the old ones back and if it starts then you have the wrong spark plugs or they were not gapped correctly.
Aug 05, 2010 | 1991 Honda Prelude
No start
petorl pump. run a live from the battery to switch to petrol pump. turn iginition on, petrol switch on an dshe should fire up, happened to two of ours.
Apr 11, 2009 | 1992 Honda Prelude
93 honda prelude dohc vtec engine will not can be push started
Sounds like you accidently pulled the thin wire from you starter motor. Look at the connections at the end of the solenoid, mounted on starter motor.The thick red wire is Battery + next to that connection is a smaller male push- on terminal, locate loose wire (thin) in the same area and reconnect to male push-on terminal on solenoid or check if earth cable between body/battery to engine wasnt removed in the process.Also some vehicles you have to engage the clutch before starting, check for a switch located on clutch pedal where master cylinder connects to clutch pedal (Is clutch switch mounted and wiring connected?)
Jan 03, 2009 | 1993 Honda Prelude
93 prelude starting problems
I had a similar problem on my 93 Prelude. Apparently the original ignition module has a high plastic content. This doesnt do well with heat obviously. I had the ignition replaced with an aftemarket part that did not use as much plastic in its pieces and it fixed the problem.
Jul 16, 2008 | 1993 Honda Prelude
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
