Need to replace the transmission in a frigidaire (FLEB43RGSO) combe washer dryer. Any tricks or special tools necessary?
  • 156 Answers
No tricks no special spaner nut wrench made to remove nut on some no special tool needed
Posted on Mar 03, 2008
I need to know how to remove the dryer from the washer on my Frigidaire Gleh1642fs1 Gallery series laundry center. I need to replace the bearings in the washer.
Dryer does not come off, you have to work through the front panel. This is not a job for the average do it yourselfer. But if your gonna dig in you'll need some speciality tools like a spanner wrench for the drive block nut and basically anything else in an average tool box for the rest, good luck.
Jun 10, 2017 | Frigidaire Washing Machines
Water outlet hose replacement
Hi, you could try copper pipe, 22mm, or 3/4" (ish) ( plumbers) and jubilee (adjustable clips, from hardware store) to clamp the two together.
Dec 06, 2017 | Splendide Comb-O-matic 6200 Non-Vented...
Its not agitaitn
You have a bad bad break package which is mounted above pulley located on bottom of machine.You need some special tool to fix this kind of problem.Hope this helps .
Thank you !
May 11, 2010 | Frigidaire FEX831CS Top Load Stacked...
Broken transmission in washer - can I replace just the washer unit? Or does the whole thing need to be replaced.
The transmission can be replaced by it's self, but it's sort of expensive. See this diagram part 3
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158202&diagram_id=1275495#d1275495
It will be even more unless you can do it yourself.
I don't know if you can replace just the washer.
Feb 17, 2010 | Frigidaire FEX831CS Top Load Stacked...
Replace wiper motor
Wiper Motor
  1. Remove the wiper blade and arm assemblies, as outlined earlier in this section.
  2. Turn the ignition ON and the wiper switch OFF so the wiper motor returns to the park position.
  3. Disconnect the negative battery cable.
  4. Unfasten any necessary retainers and remove the air inlet screen assembly. Disconnect the washer hoses.
Remove the air inlet screen retaining bolts/screws ...
... then remove the air inlet screen
Disconnect the windshield washer fluid hose(s)
  1. Disconnect the wiper arm transmission drive link from the crank arm using a suitable wiper transmission separator tool.
There is a special tool available to separate the transmission drive link from the crank arm
View of the transmission drive link separated from the crank arm
On some vehicles, it may be necessary to remove the nut from the ball crank and remove the crank arm.
Location of the wiper arm ball crank
If necessary, unfasten the ball crank retaining nut, then remove the crank arm
Detach the electrical connectors from the wiper motor. Remove the wiper motor mounting bolts/screws.
Feb 06, 2010 | 1997 Buick LeSabre
I need to replace the dryer belt from a Kenmore washer dryer comb
Remove the top lid, then the front panel to access the drum and belt. Unplug the dryer first.
Jun 07, 2009 | Kenmore Dryers
Frigidaire dryer rear spindle
This Should Be Lubricated, Providing The right Lube Is Used.
You need To grease The Bearings With A high Melting point Grease. Copperease Or Similar. ( I,m not sure What the Americans Use ) alternatively A little Vaseline ( Petroleum Jelly Should Do the Trick ) Always Works Wonders For Me :)
If The Bearing Race ( Holder ) Has Broken, Then A replacement Will be Necessary, This will involve A gear Puller Or similar to remove.
If the bearing is Grating Or grinding, lubricant is only a short term fix.
Mike @ Compurepair.
Feb 28, 2008 | Dryers
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
