Question about Uniden Cordless Phone
I wish to delete a name and add another name and number but I can not get to the edit function on the name list. uniden phone
  • Anonymous Mar 11, 2008
    Want to delete 1 phone name & number in the directory and add another
I went on line and found a location that allowed me to down load the manual for the Uniden phone in question. With the instructions I was able to solve my problem.
CHersey
Posted on Feb 29, 2008
HOw do I unblock a number from my Uniden DECT 6.0 home phone?
Call block entry options:
With the phone in standby, open the call block list and find the entry you want.
Press Menu/select to open the individual entry menu. Choose one of these options:
  1. Edit (Handset only) Edit this entry. The phone will prompt you to edit the name & phone number.
  2. Delete Erase this entry from the list & allow calls from this number.
Dec 20, 2017 | Uniden Lands Phones
How do I unblock a phone number on my uniden dect 6.0 phone
May 22, 2015 | Uniden Lands Phones
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
New phone DECT1480. How do I delete the new cid numbers
To select a number, highlight the number and press Menu/select. The phone gives you the following 3 options:
1) Delete Entry Erase the number from the list.
2) Store Into Pb Add the number to the phonebook. The handset prompts you to edit the name and number.
3) Delete All (CID list only) Erase all numbers from the list.
Friends phone:
1) Check batteries
2) Check base unit has good mains connection ! faulty mains extension
Oct 18, 2017 | Uniden Lands Phones
How to delete or edit phone numbers
Go to Phone book on your phone. It will display the Names List/Phone numbers you have saved.
Click on the number you want to edit/delete. Once the name/number is displayed, click on options and then Edit/Delete the Name/Number.
May 06, 2011 | Vacuums
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Mar 27, 2009 | Uniden BC246T Handheld Scanner
Cannot edit stored phone numbers
goto phone book hit menu find the number and or persons name you want to edit edit the number hit ok to get to the number or you can do the easier way
delete there name and number and put it back in with the right digits
May 30, 2008 | Uniden Cordless Phone
Unable to Store Phone Numbers
The store memory function is very similar to this phone in the EXA series phone made my Uniden.
See the instructions to store/delete/add numbers in the manual below on page 22.
http://www.uniden.com/pdf/EXAI2248Iom.pdf
hope this helps
- Pete
Jan 31, 2008 | Uniden Cordless phone EXS9950
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
