The problem is the internal battery that powers the storage of time and date. If the camera is unused for a while, it will discharge. You must put a freshly charge battery into the camera and leave it with the power turned off for 24 hours to charge the internal battery. If it doesn't charge in that time, I suspect it needs to be replaced.
Have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
