Question about Refrigerators
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Hi Guys, I have a Samsung Fridge Freezer (freezer on top) Model SR-52NXA. Neither the fridge or freezer are cooling. Compressor fan is working &; commpressor seems to be working(humming).However the compressor is very hot to touch. Do you have any steps I can check to try and eliminate problem.
Regards
Simon
    Problem Solver:
  • 5 Answers
Pl check compressor running r not .......compressor is very hot it for overload cool the compresor & check for condensor fan its working r not.......
Posted on Apr 06, 2009
  • 247 Answers
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
My samsung refigrator Model SR-57NXA not cooling properly
HI TAHIR.try defrosting all for 24/48 hours first.good luck.Ali
Jun 25, 2012 | Refrigerators
I HAVE A SAMSUNG HALF AND HALF FRIDGE FREEZER MODEL NUMBER RL36EBSW THE PROBLEM IS THE FRIDGE WONT GET COLD
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Refrigerators
Sanyo SR-4800W freezer is ok and cold stoeage is warm. Need to fix the problem.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Sanyo SR-4800 Top Freezer Refrigerator
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Feb 28, 2010 | Samsung Refrigerators
Refrigerators Logo
709 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
