Question about Eureka Atlantis 2595A Upright Wet/Dry Vacuum
Leaking Carper Shampooer
My carper Shampooer leaks out the shampoo all over the carper even before I turn on the shampooer. The tank has also started to leak. The shampooer is a Eureka and it is only 1-1/2 years old. Of course the warranty has expired. Any suggestions? Thanks!
  • Anonymous Aug 28, 2008
    I have the same problem. I fill the tank with hot water, and if I don't get it in quite right, there is water water everywhere. Repositioning the tank did help each time, but I agree that it is a design flaw.
    I am also struggling with the fact that no water is coming out of the upholstery nozzle any more. I've taken the handle apart, and looked at the button under there. The button seems to get stuck, and I agree perhaps there is not enough height in the button design. I am going to try adding a pad to improve the contact. When I took it apart I found a spring laying around after I had taken it apart. Is there a spring in there somewhere?
    Scholar:
  • 161 Answers
I have contacted Eureka and they have suggested I send back the serial number label, and describe the problems I am having with it. They have offered/suggested in my phone call to them, that they would likely replace the unit. I'll see how it turns out. Just sent the letter away (Sep 2, 2008).
Posted on Sep 03, 2008
    Guru:
  • 147 Answers
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much.
The manual says to "push the tank in until it snaps into place". Everything looks fine across the board so I believe this particular model is just a bad design overall.
My recomendation: Get a new carpet cleaner from Target or Wal-Mart.
Please let me know if this helps. Good luck!
Posted on Feb 28, 2008
Liquid comes out of shampooer but it isn't sudsy. What could be wrong?
Check the Shampooer Tank seating. Turn the unit off and unplug. Remove the Shampooer Tank and inspect the reservoir for any foreign substance. Reseat tank. Replug and turn on unit. Remember to keep your filters clean. There's the lint filter on the cap of the main tank and there's the Flow Filter (Turn Flow Indicator Cap counter-clockwise to remove, remove rotor, and filter is under it. Clean and replace in reverse.) Bissell Consumer Care 1-800-237-7691 if you need. Additionally check you Use Guide for more information.
Nov 25, 2015 | Bissell Lift-Off Pet Deep Cleaner
Upright carper shampooer Bissell with mixer feature will not spray solution and water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
y46
Sep 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
Apr 11, 2009 | Kirby G6 Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
NEED MANUAL OR INSTRUCTIONS FOR DURABRAND DUAL POWER VACUUM/BLOWER
I have an Eureka Atlantis Opti Heat Carper Shampooer Model 2596. I do not have an instruction book. What I need to know is how much carpet cleaner & water to mix together.
May 02, 2008 | Vacuums
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
KIRBY SHAMPOOER shampoo TANK G3, ULTIMATE G DIAMOND
The bag assembly must be removed to attach the tank. Turn the fiberglass bag housing counterclockwise to remove, and replace it with the tank.
Dec 21, 2007 | Vacuums
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Phil-T
Sep 07, 2007 | Vacuums
Eureka Atlantis 2595A Upright Wet/Dry Vacuum Logo
578 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
