Question about Microwave Ovens
Amana mvh230 microwave
Oven does not heat up and it makes a humming noise
  • yaryar Feb 29, 2008
    Found two fuses inside the microwave, a white one in good condition and a blown fuse which is encase in a plastic device
  • Anonymous May 01, 2008
    Dear Sir,
    I have a GALANZ microwave which once gave a bursting noise while operating.Same used after wards found workin but stopped using for any more bursting fear.Same opened up found lots of Cockroach eggs ,cleaned throughlyand boxed back.Found working but a noise like wire touching fan blades.Same opened up again wire separated from the fan instrument boxed back foung magnetron humming sound is there but not heating atall.Pls advise.....
    Santanu Lahiri
    Kolkata
    Cell 0 9433620930
    Scholar:
  • 135 Answers
Hi there!
The magnetron has probably failed. Check the High Voltage Diode for short circuit. Replace protection fuse with same value. The Diode is standard on most microwaves. Magnetron to be replaced with the same profile and wattage. Be sure to unplug Mains before opening the unit. Good Luck, JUS004
Posted on Feb 29, 2008
Why won't the turntable turn?
this model DOES use a probe,look inside for a port,like a headphone plug,unplug your microwave and use a couple toothpicks and gently push thenm into hole and move around to make sure no food is in there,then plug back in and try,or reset,do not touch accu temp,if still nothing then there is a bad plug,here is your manual,,
http://www.manualslib.com/manual/733847/Amana-Mvh330.html?page=2#manual
Mar 21, 2015 | Amana MVH230 Microwave Oven
Beeper problem
wither it fell out of place or needs replacement
Apr 17, 2014 | Amana MVH230 Microwave Oven
Inline bus fuse continues to blow
The magnetron in the microwave oven is shorted, "heats food"
Mar 25, 2012 | Amana MVH230 Microwave Oven
Makes a humming noise wont heat
If its making a humming noise, that means the diode is bad and should be replaced. Once replaced the microwave will begin to heat again.
Feb 11, 2011 | Kenmore 62622 Microwave Oven
IT JUST STARTED MAKING ALOUD HUMMING NOISE.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | Amana ACO1860 Microwave Oven
Is there any better resource for a door handle (ps2172561) for an Amana MVH230W than paying $90+shipping online? That seems outrageous for a plastic 12" handle. I guess when youc an't open your microwave...
The Amana / Whirlpool / Maytag part number is R0713642 and you can get it for far less at one of the places listed here.
Nov 24, 2009 | Amana MVH230 Microwave Oven
It is making a humming noise but not heating.
sounds like a crack in the magnetron
a bad transformer
or a bad rectifier
sorry i cant be more help
Oct 10, 2009 | Maytag MMV5100A Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Microwave Ovens Logo
458 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
