Question about Dishwashers
Problem with Candy CDI45, Error E4
I have a Candy CDI45 diswasher and it is throwing error E4. I believe it means that it cant discharge water. Is this true? How to solve this problem or find out what is causing it?
The instruction manual defines E4 as "overfilled", a possible reason being too much inlet water. What helped with our machine - removed all dishes inside, then let the machine's pump run briefly to make sure as much water was drained from the system as possible. I then unplugged the device, placed a large towel on the floor around its base, and tilted the machine front-ward, until all water had run out. Lifted the machine back upright, plugged it in, switched on - and voilà! it's working as I speak.
Posted on Nov 06, 2009
  • GORAN Feb 14, 2013
    thanks,it works fine now,thanks again,best regards,Goran-Croatia
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
My candy CDI45 is not working, it just keeps beeping and saying E2. Any tips on getting it working again would make me a happy lady again.
Hi.
E2 is called water safety level error. Unfortunately the problem is often caused by either a defective pressure switch or by a defective control board. The problem is quite common in SMEG built dishwashers like your Candy.
All you can do is disconnecting power for a couple of minutes, by either tripping circuit breaker or disconnecting power cord. That will reset control module. While power is off remove water (if any) from the bottom of the appliance.
If that does not do the job the parts must be tested and the appliance must be repaired replacing defective part.
Regards.
Ginko
Aug 18, 2011 | Dishwashers
Dishwasher has been stored for a few months, we have just connected it back up and switched and error code E4 has come up. What does this mean and how to I rectify it?
E4 means that the dishwasher has a problem with discharging water. Check that the discharge tube is not bent and the siphon is not blocked and the filters are not blocked. Depending on how you stored the dishwasher, check for evidence of rodents or insects building nests in the unit.
The manual for the HD97 is available from Hoover at http://service.hoover.co.uk/manuals/Manuals.aspx?Section=3 . Enter the model number and the link will come up. The manual for the free-standing version does not seem to be available separately.
I hope this helps.
Jun 12, 2011 | Hoover 24 in. HD97E Free-standing...
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
May 31, 2011 | Kenwood Dishwashers
What does E4 flashing mean?
E4 means that it is not able to discharge water.
Make sure all water is pumped out of the machine. Switch it off at the wall and unplug. Tilt the machine forward (put a towel down first) all the way till the door is on the floor, and let the rest of the water run out. Return upright.
Hope helps.
Apr 14, 2011 | Candy Dishwashers
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
Need to know what a E4 reading on the runyes autoclave means
E4 error is a pressure and temperature differential. Check the steam generator solenoid,steam generator water pump and water sensor in clean water reservoir. If any of these components are faulty then replace. If all ok refer to E2 error and check inner temperature sensor or check for steam leaks
Sep 13, 2010 | Health & Beauty
I have a Candy dishwasher. Door is open switch on sounds like something (possibly pump) is running and error E4 shown on diaplay. Any ideas please?
Overflow tray (bottom dishwasher). Tilt your dishwasher, pour water and see the reason for the overflow. I blew off the top hose from the pump.
Jul 20, 2010 | Candy 17 in. CS455 Built-in Dishwasher
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwashers Logo
1,749 people viewed this question
Top Dishwashers Experts
