Performance issues are usually simple to resolve. DC11 has two filters - the 2-part pre-filter (the yellow plastic outer casing the the blue foam inner section) should be washed at least once every three months. The post-filter is engineered to last the lifetime of the machine without maintenance or replacement. If you have washed the post-filter, unfortunately this may have caused damage and we would recommend replacing it.
If you'd like some further advice from our experts after you've given this a try, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
With the exception of the sole plate and brush bar, the Turbine head is manufactured as a complete assembly. We wouldn't recommend attempting to dismantle it as we can't guarantee this won't cause damage. You might want to take a look at our Support guide, as it may be possible to resolve the issue with some simple troubleshooting:
I'm sorry to hear you're having difficulties with your DC11. From your description of the issue, it sounds as if you may have a blockage in the turbinehead. To check for and remove any blockages, please follow the steps shown in our online support guide:
I can't tell from the information provided what sort of issue you're having with your mini turbine head, but you may find our support guide of use in resolving any difficulties:
The Turbine head on the DC11 range is not powered by a motor, it is air driven. If the performance of this tool has reduced, this is most likely caused by a dirty filter or a blockage in the head or the machine.
To clear, please visit our support section online at www.dyson.com.
If you have a different product that does have a motorised head, you will also be able to locate information on how to reolve this via the online support section.
I have taken the brush heads off and pulled all the hair out of the small gap between the chrome shaft and the plastic gear housing. Then a small amount of 3-in-1 oil into that gap to lube the internals and just a little through the air intake on the side of the head to clean and lube the seals and it works like new. This lasts about 9 months under high use and the process takes roughly 10 minutes.
