Question about Dell 962 Photo All-In-One InkJet Printer
Fax when it is recieving a fax it just keeps ringing out. auto answer not picking up.
  • gapmon Feb 29, 2008
    worked fine
  • 106 Answers
You must to enter at menu or setup in your fax and turn on auto answer,and to chose number of ringing before fax answer
Posted on Feb 28, 2008
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
Fax will ring but not pick up fax
hello, on the control panel to this machine, there is an area for the fax setting, there is also a button, that has an light on it for AUTO ANSWER, the light should be on for recieving faxes. also, i would set the answer on rings for 2.
Oct 01, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canot recieve fax
Try these settings ::>>
1.) Press Setup
2.) Select Fax Settings, then press OK
3.) Select Communication, then press OK
< under communication try these settings >
> DRD should be all
> ECM should be off
> V.34 should be off
> Rings to answer ( if you have an answering machine?
or a voice mail service either virtual or physical.,
check how many rings does it have before it picks up )
set your printers rings to answer about 2 rings higher than these devices.
> Auto answer on the control Panel of the printer should be on / enabled
Note ::>> If still cannot receive a fax? try to disconnect your voice mail or
answering machine to the line to Isolate Issue whether printer cannot receive
a fax or the said devices is having an issue with the printers fax
receiving capability.
Mar 28, 2009 | Epson Stylus CX9400 Photo Printer
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
You have to answer the hone to recieve the fax
Try unplugging the power cord for 10 seconds to reset the machine.
Scroll through the menus and set your machine to AUTO or AUTO RECEIVE.
Nov 25, 2008 | Brother MFC-8220 Fax
Make sure the Auto answer the button is on....
Reset the printer setting to default and set the rings again to 3...and try..
Jun 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
109 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
