Question about Danby Dishwashers
Ddw counter top
Dishes are not cleaning.
Thanks for your reply.
I finally found the instruction booklet and used the method
of adding Vinegar and problem was solved.
Thanks
Posted on Mar 03, 2008
Past tense
no-- all present tense
it is all things to do now
Feb 28, 2017 | Refrigerators
Tip
I have problem with DDW-081 recorder it doesn't read CD at allĀ  it read DVD OK...
shove it We encourage you to use Tips and Tricks as a starting point for sharing your technical knowledge and know-how with other FixYa users.
on Aug 24, 2008 | Pioneer DVR-107D DVD±RW Burner
Past tense
this is a site for fixes not complaints
Aug 22, 2014 | Refrigerators
Defy DDW 169 manual
My Defy DDW 169 Dishwasher won't go beyone draining on starting a wash cycle. What is the problem with the machine?
Dec 18, 2013 | Washing Machines
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Jul 20, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
Bottom rack cleans fine, top rack doesn't clean at all - can I take apart the top spray arm?
yes, the spray arm can be removed and cleaned out.
Also, clean the 3rd (very top spray area) located attached to the top of the dishwasher. You want to make sure this small (1 inch size) piece can spin freely, so water can rinse the upper rack items.
Feb 01, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Lite-On LVW-5005 (DDW-813s)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A4P, it work perfectly, good as new. but you have to make some changes to fix it to the place
Oct 01, 2007 | Lite On LVW-5005 DVD Recorder
Dishwashers Logo
165 people viewed this question
Top Danby Dishwashers Experts
Jose Pino
Carmen Mikulic
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
