Question about Linksys Wireless-G WRT54G Router
Ethernet problem wireless g adsl gateway with 4 port switch The dsl internet locks on as does the wireless for the laptop (which connects fine) but the ethernet cable will not connect so I cannot go online with the desktop. Keep getting a message saying the cable is unplugged (which it isn't). Now have 30 e-mails backed up which i need to get to
  • 55 Answers
1. Restart your router
2. Restart your computer
3. Check your ethernet cable. Try another one if possible
4. Try to connect to another port on your router
10. Your port on your PC is dead(Heat by lightening)
11. Your router is bad
Posted on Feb 29, 2008
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
My ADSL 2+ works fine with wireless, but not with a local area connection. My PC uses this. I,ve switched cables, tried a cable with the laptop, and reset the router. No change. Any ideas? Steve
If the wireless connection is working fine it show that your internet security is fine and you can access net without problem
there could be a connection issues a within the cables
1) Connect the Ethernet cable to the Laptop and connect the other end to router E1.
2) Open the command windows (DOS ) by typing cmd or command on the Run option ..
START- RUN- type command then hit Enter
3) In the black command windows - Type IPCONFIG
c:\> IPCONFIG hit enter
it will provide with the correct IP ADDRESS and Gate Way Address
Check the gateway address - shout strat with 192.168.X.X
If it is not there is some problem -
4) Check the Device manager and check the Ethernet Adapter whether the adapter is enabled or Disables or Drivers are installed or not
Aug 10, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I am wanting to run my (currently wired) laptop to be wireless (have bought a USB adaptor to do this), but also keep my main PC wired. I clearly need the internet on my PC to set up my DLink G ADSL2+. I...
You will need a wireless router with a built in switch. Most of them these days will have a built in switch. Here is a picture detailing what I am talking about.
You're internet connection goes into the ADSL port. Now, it will be broadcast WIRELESSLY through the antenna to your laptop. With this example, you could connect 4 more WIRED computers through the LAN ports. The built in switch is the division of the connection into the separate LAN ports.
I trust that this will help you greatly and look forward to your response!
Feb 26, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I HAVE A D LINK ADSL MODEM MODEL 502 T. AND ALSO HAVE A BRAOAD BAND INTERNET CONNECTION OF BSNL BUT IT IS NOT WORKING PLEASE ASSIST ME WITH CONFIGURING STEPS
connect the DSL end to the INTERNET port in your modem. then in the ETHERNET ports, connect any computers. then from there you should be able to access internet. if not, follow this to configure
1. in a PC connected to your modem, open a browser and visit http://192.168.0.1
when prompted: username = admin password = admin (or try also <blank> or no password
Sep 28, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
