Question about RCA F27242GY 27" TV
TELEVISION TV TURN ON AND THEN INSTANTLY TURN OFF
  • tiaralake Aug 20, 2008
    I have a 32" RCA television that is 12 years old. It loses the picture after the tv is on for about a 1/2 hour. Sometimes it comes back on by itself, or after waiting 10 minutes or so I can turn on using the remote. A few times the screen goes down to a horizontal white bar and then returns to normal in an instant. It seems to me something is overheating and shutting down until it cools down, but I am not sure. From day one the TV usually requires 2 or 3 pushes of the ON button to turn on properly.
    Problem Solver:
  • 3 Answers
I had a similar problem on a 27" RCA and the solution was replacing the regulator and the surrounding components, there is a regulator kit that has all the components that are to be replaced, at the parts store you need to quote the model # and they should be able to tell you the kit
Posted on May 26, 2008
  • refrigerant May 26, 2008
    I did some checking, it was the same model television and the part # for the kit was 231523 hope this will help
    Scholar:
  • 133 Answers
Not sure what model # it is , it sounds like a bad flyback transformer. If you can solder and unsolder you may fix it yourself for under $30.00 . If not a shop might charge you $85 to $110 .
Posted on Feb 28, 2008
Tv wont turn on
With set unplugged remove rear cover and follow the power cord to the fuse--good or bad? This set should also have some led lights there that are green or red---look to see if any are lit or if when plugged in with back removed which come on or go off instantly, the reason I ask is those are each tied to a voltage source and will point to where the problem MAY be.
Dec 21, 2012 | Hitachi 51F710 Rear Projection Television
I have a sanyo 50 inch plasma tv. while im playing games on my xbox 360 there is controller delay as you turn to look at objects ect. i have been using the av cord provided with xbox and now have an hdmi...
NEW TV's HAVE TO PROCESS INPUT FROM CONSOLES
and it takes time
i am MLG and if you want better reaction speed use an older television which generally respond instantly
Apr 23, 2011 | Microsoft Xbox 360 Console
Overheat of Akai LCD TV and cannot turn on again, why?
Now the tv is turn on.Any LED power light indication on the LCD panel flashes at all or no light,nothing at all?Yes,than the power supply board it dead.That the board where the power a/c plug into it.But the Tuner board,that the board where the coalax cable brocast signal plug into,might also burn too.Tries websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement and the refurbish Tuner board also.
Jul 19, 2010 | Akai LCT3201AD 32 in. LCD Television
Tv blowing fuses
More likely to be either shorted out bridge rectifier or MOSFET in the primary circuits of the power supply. You need to Ohm out those parts.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sylvania+LC320SS8+
Dec 22, 2009 | Sylvania LC320SS8 32 in. LCD Television
Recently, the color started going in and out.
Sounds like the power switch has gone bad, Have a repairman look at it.
Don't try this yourself. There are components inside that tv that can kill you instantly if touched.
Sep 30, 2009 | Mitsubishi WS-55819 55" Rear Projection...
TV wont turn on, sandby light flashes 7 times.
Any malfunction associated with a flashing stand-by light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
TV WONT TURN ON, STAND BY LIGHT FLASHING 3 TIMES CONTINUOUSLY
having problem with sony television the screen when its turn on no images found just found red color on the screen..
Feb 01, 2009 | Panasonic TX-42PT10 42" TV
Akai LCT2662
You're getting some feedback on the secondary transformer - most likely... Try to isolate where the pitch is coming from and see if it's harmonic. May just need to be glued down or have some leverage place against it...
Bill
Apr 01, 2008 | Akai LCT2662 Television
RCA F27242GY 27" TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
