Question about Dell 1710n Laser Printer
Dell 1710n printer problem...
The toner low light & error light will not go out on Dell 1710n printer. The toner has been replaced and there is no existing paper jam!?
  • 7 more comments
  • katorrence Mar 10, 2008
    The "error !" light just started coming on. We have no paper jam and the ink cartridge in the machine is only a few weeks old. We have tried turning it off and on and unplugged the machine for a few minutes but it always resets with the "error !" light on.
  • Anonymous Mar 13, 2008
    Exactly the same problem !!. Changed toner cartridge same problem. Cannot reset opc counter. Tried going into settings and resetting factory default. Problem still persists.
    AndyM
  • Anonymous Apr 01, 2008
    I had the same problem - when I put the old cartridge back in the error light went out and the printer started running again. The toner light is still on. I was trying to replace it with an off brand cartridge - I would suggest only using only a Dell cartridge!
  • Anonymous Nov 15, 2008
    Same for me too. Replaced the toner and reset the drum counter, but the toner light and error light stay on.
    same for me
  • 280958209854 Nov 20, 2008
    We're using a refurbished cartridge and the new one give the same error. I put a old Dell own back in and it was fine.
  • dredding Dec 01, 2008
    will not print and all lights are on and will not reset.
  • Anonymous Apr 10, 2009
    how od I resent the printer page count?
    chrisnabinger@yahoo.com
  • Anonymous Mar 14, 2014
    printer will begin to print and then stops with a toner sensor error
Try resetting the error lights with a drum reset. With the power on and cartridge door open, press and hold the Cancel button until all lights flash in sequence. Release the button and close the door.
Posted on Mar 26, 2008
One off brand I've found that works is IPW... or any brand with a "green" handle. Not blue... the only blue handle I've found to work is an actual Dell toner cartridge.
Posted on Apr 02, 2008
  • Ringding Apr 02, 2008
    One thing I just found that works. On the underside of the toner that works is a colored chip... this is the cause of the error. The chip is only glued/rubber cemented on the toner, it is not connected to the cartridge in any other fashion (ie, wires). Take the chip off the toner that works and the new toner you rec'd that doesn't work (generates and error), switch the chips with the toners and bingo, you're back in business. Make sure you get a good stick with the chip to the new cartridge (do NOT super glue, you may need it in the future and you don't want to snap the chip... rubber cement if needed) just get it to stick so it doesn't fall off.
  • elizabeth Aug 26, 2013
    Thank-you this worked for me. I changed the chip. Luckily the glue on the chip was still sticky enough to fasten without adding anything. I'm very glad I did not recycle my old cartridge like I was going to!
I did have this problem with when replacing a Dell toner with another Dell toner, was strange but was able to put in a refurb toner and did the reseting cycle and that did fix it.
Posted on Jul 22, 2008
I had this same problem and I worked with the printer forever and tried everything. Finally, I put the old cartridge back in and it fixed the problem - I would make sure to use a Dell cartridge in the printer and not an off brand or refurbished.
Posted on Apr 01, 2008
Download for driver
Posted on May 12, 2009
The sun light and the deum icon +error message ! sign are both blinking on my Dell 1710 i have changed the toner drum but it keeps blinking should i have to change the inside drum too. because the last...
Here is a link to your printers manual. It has troubleshooting in it and explains what the error means when you see the picture of the sun with the ink drop & exclamation point blinking. It also has instructions on how to fix the error and stop the blinking.
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Oct 14, 2011 | Dell 1710n Laser Printer
My dell 1710 printer prints very light but the low toner light isnt on.
Check your print settings by properties. The setting might me on toner save mode so it will print 50% liter or which ever one someone press. It could of been my mistake but it must be toner save mode is on.
Good luck!!
Please rate me good
Jul 14, 2010 | Dell 1710n Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Help
There is no setting on the 1710 printer to clear the error of a non Dell branded toner being inserted. Some higher end Dell printers do have a setting for Non-Dell branded toner. Not all Dell printers have this setting. Resetting the drum count will have no effect on a non dell branded toner error.
Nov 07, 2008 | Dell 1710n Laser Printer
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
1710N
The solution I used and the one I suggest is to switch to another brand and NEVER buy another Dell product. Until recently, everything in my office was Dell. Eventually everything will be other than Dell. Their support is terrible and I think the quality of their products has deteriorated over the years.
Mar 17, 2008 | Dell 1710n Laser Printer
Dell 1710
it's in the menu, under settings. reset to default and then power cycle it again...sounds like your memory is a bit corrupted(comes from power glitches)
Jan 18, 2008 | Dell 1710n Laser Printer
Dell 1710 lights
You need to replace the drum and toner to correct the issue. That's the sign of the drum at its end of life.
Nov 02, 2007 | Dell 1710n Laser Printer
Printer doesn't print
You need to replace your imaging drum. There is no bypass for this. Let us know if you have any more questions and please don't forget to rate this post.
Mar 14, 2007 | Dell 1710n Laser Printer
Dell 1710n Laser Printer Logo
2,038 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
