PCI Is a PCI-E primary function to connect servers to storage via ethernet or fiber cannel?
    Guru:
  • 147 Answers
"As of 2007, PCI Express has replaced AGP as the most common interface for graphics cards on new systems. With a few exceptions, all graphics cards being released today (2008) from ATI and NVIDIA use PCI Express. NVIDIA uses the high bandwidth data transfer of PCIe for its newly developed Scalable Link Interface (SLI) technology, which allows two graphics cards of the same chipset and model number to be run as a pair, allowing increased performance. ATI also has developed a dual-GPU system based on PCIe called CrossFire. Towards the end of 2007, AMD released a motherboard chipset, the AMD 790FX, which supports up to four PCIe x16 slots, allowing tri-GPU and quad-GPU configurations for ATI cards.
Uptake for other forms of PC expansion has been much slower and PCI remains dominant. PCI Express is commonly used for onboard gigabit ethernet and wi-fi but add-in cards are still generally PCI, particularly at the lower end of the market. Sound cards, modems, serial port cards and other cards with low-speed interfaces are still nearly all PCI. For this reason most motherboards supporting PCI Express offer legacy PCI slots as well."
Source/Link: WikiPedia
Please let me know if this helps. Good luck!
Posted on Feb 28, 2008
Hp a345w desktop pc dcs server not found conflict
what OS, we can NOT GUESS your operating system.
so where are you , home or star bucks.?
what is your connection, wifi, ethernet, or others?
a desktop pc can have vast ways to get internet.
1: modem dial up (i bet not this, nobody uses this now, 99.9)
2: cable modem, sat modem, fiber modem to ISP
3: USB wifi dongle, on PC and to local router.
4: PCI card wifi. , to router.
5: ethernet wired to router or modem direct. a cable wire. CAT5/6
one can even have direct wired ethernet to the cable modem
or you might have wired to wifi router (2 ways to connect there)
NO OS stated
no connections stated.
my guess is DCS, means DHCP not found, or DNS not found.
lots of causes, but I will not attempt to answer for all 6 ways.
sorry
May 30, 2017 | HP Computers & Internet
Integrated ethernet card on Compaq Model SR1650NX apparently failed. What is best inexpensive PCI Ethernet Card to use, if any?
you can buy just about any PCI NIC card from ebay or even walmart and they should work. make sure they are compatible with your OS. it will say on the box.
Jun 11, 2012 | HP Compaq Presario SR1650NX...
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
I have a Geforce 8400gs PCI video card
Helo frnd i sugest u to reset ur bios by opening the mobo n find a jumper were clear cmos is written then fix the jumper to the other two sides oor read the mobo manual to do it
Feb 19, 2010 | Asrock P4VM890 - Motherboard - micro ATX -...
My computer fell and when I turned it back on it's saying check cable connection..! PXE-E63: Error while initializing the NIC pxe-m0f:Exiting Intel pxe rom no bootable device
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Nov 09, 2009 | Acer Aspire One PC Notebook
Actally i wanted to know how server works & data is transferred
in general & simple terms, a server, when used as a file storage device, works by creating a shared drive or directory on the server, and giving proper read and write permissions to the desired users. From there, the files are transferred via network connections (wireless, ethernet, etc.) Hope this helps
Jan 08, 2009 | Computers & Internet
Slow file transfer
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
Aug 15, 2007 | EMC CLARiiON AX150 (AXS207500KIT) Network...
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Electro Med Services...
