Question about Avaya Corded Phone avaparp18d
ATT MLS-18D - Partner II, Release 3 System
I have call waiting, but cannot access the key. The provider says to hit the flash key - I don't have flash key. They sais to tap the receiver key and that hangs up the line. Help.
You need to program the feature "recall" on a button.
On the phone you want to program, press Feature 00
press a button you can program as "Recall"
press feature 03
when finished, press feature 00 and you are done.
Recall is the "flash" button
Posted on Jun 03, 2008
How to programming light on/off when have massage?
Posted on Mar 16, 2009
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
How do i change the time on my avaya 18d series 2 partner phone
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
Sep 10, 2010 | Avaya Eurostyle 18D Corded Phone
How do I turn off the local ringer on my office phone, AT&T MLS12D
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
Press feature "00" to logout
Apr 29, 2010 | AT&T Lucent MLS-12D Phone
How do I change the time on my Lucent Partner 18d
3. Enter # 103
Mar 30, 2010 | Lucent PARTNER18 Corded Phone
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Ayaya Lucent Partner 18D Cordless call waiting.
The cordless will not work that way. If you hit flash, that will put calls on hold, etc....
The only thing you can do is have the flash button on the 18D itself.
Aug 28, 2009 | Avaya Lucent Partner 616 Phone
Need to reset Time/Day on it
This should do ya.
http://dstech1.com/changing-time-on-a-partner/
May 18, 2009 | Avaya MLS 18D Corded Phone
MLS-12d phone system
Your system is actually called Partner.
Compatible phones will consist of MLS12, MLS12D(display),Mls18, 18D(caller id display), 6D(display), 34, 34D(display) No other phone will work on this system
To program phone numbers
Press Feature 00, press/select a buton to program, input speed dial number. Press Feature 00 again.
Mar 22, 2009 | AT&T Lucent MLS-12D Phone
Is there a Conference Call feature on ATT MLS 12D?
If by conference you mean inside and outside parties connected together the answer is yes. You should have a CONF button on the set. You press CONF, dial your second call and press CONF again. You can press CONF again and do it all over again to add a 4th party. There are restrictions and the conference is not amplified.
Here's a User guide to Partner phones. pdf page 3 has CONFERENCE instructions.
http://public.carl.airpost.net/Avaya/Partner%20Phone%20User%20Guide.pdf
Carl
Feb 27, 2009 | AT&T Lucent MLS-12D Phone
Noise in system
Probably in the module. Switch to different port on module and see if it clears the problem
Jun 17, 2008 | AT&T Partner 18 Phone (315805B)
Avaya Corded Phone avaparp18d Logo
371 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
