Move wires around gas valve to see it there is a loose electrical connection then with a volt tester check and see if you have 24 volts at the gas valve, if you do have voltage at gas valve, replace valve.Also check furnace filer make sure it is cleaned, unit could be off on high limit, check limit (s) control (s) with ohms meter for continuity, good luck.
