Question about Vacuums
Changing a Belt
I need instructions on how to change the belt on my Hoover Elite Supreme.
Thank You,
Linda Troy
    President:
  • 1,673 Answers
Take the bottom plate off, the brush roll and belt are there, you may have to take the top off, there maybe 2 screws from the bottom to remove, then on the sides there is a slot for a screwdriver to fit into and pry up then the top cover comes off and you can put the belt on the brush roll and hook it around the motor shaft.
Posted on Feb 28, 2008
Hoover Windtunnel model U6485200B troubleshooting brush not spinning
Hi! The brush-roll feature needs to be engaged for the belt to tighten, so when checking the belt it will appear to be loose. Be sure you have replaced both belts on the vacuum with genuine Hoover parts. This unit takes belt 38528034 and 38528035. Also, make sure the vacuum is on carpet mode. Follow the link to view the instruction manual which provides instructions and illustrations on changing the belt to be sure it is assembled properly.
http://hoover.com/file/509/
Hope this helps!
Aug 08, 2014 | Hoover Vacuums
Is there a trick to getting the belt on the motor pulley and brush on the Hoover Elite Supreme
hi ,try warming the belt up in hot water first it will stretch better
Apr 08, 2013 | Vacuums
Ihoover elite supreme vaccum belt u5071-930
Remove the hood by popping the 4 tabs holding it on with a flat blade screwdriver. There are arrows on the bottom telling you where to pry. Lift the hood off you will see where the belt runs clearly. Stretch the belt into place and replace the hood. I'll include the link to the correct belt as well.
http://www.vacuummedic.com/product.php?id=8
Good Luck!
Vac Dr.
Sep 30, 2012 | Hoover U5227-930 Elite Upright Vacuum
I need a replacement belt for Hoover Elite upright vaccum ,model no. U5043-930. What belt do I get?
Your vacuum cleaner originally came with Hoover belt part number 38528027, however Hoover has now discontinued this part number, and replaced this belt with the new belt which is part number 38528040.
The new belt is a little bit smaller then your old one, but unfortunately this is the only belt that Hoover currently makes that will fit your model.
Here's a direct link to our website if you still need to purchase one:
http://www.govacuum.com/agbelhoovpar7.html
I have also uploaded the parts diagram and instruction manual for you. The parts diagram gives you every single part number for all parts on your vacuum should ever need to know another part number. The owners manual will give you step by step instructions on how to change the belt, as well as other maintenance instructions.
Part Diagram for Hoover U5227-930:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/Part-diagram-hoover-u5043-930.pdf
Owners manual is actually for the commercial version of your vacuum, but this will be identical to your instruction manual which Hoover doesn't have available for free:
http://www.hoover.com/pdfs/manuals/C1414900.pdf
I hope that this information was helpful to you. If it was, please be so kind and rate my repair helpful by clicking the thumbs up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Hoover U5227-930 Elite Upright Vacuum
My HooverDeluxe Elite Rewind became extra loud
If the belt is really worn it can cause that. I wold try changing the belt if you haven't recently. Here are the belts you need:
Hoover Elite Rewind Belts
Nov 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Instructions on changing a belt on an Elite Hoover Vacuum Cleaner Model # v5075-930 Serial # 089500053577
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=825812
Generic problem for all Vacuums
Posted by ed_maxwell on Jul 24, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 24, 2008 | Vacuums
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Changing the belt
I'm not familiar with that model, as it is fairly new to the market, but the previous models had a plastic plate that covered the roller. There are two clips that must be depressed as you gently pull the plate away from the machine. This will allow the removal of the plate so that the roller can be removed and a new belt installed. This is a new model, so you must have the manual still. You can also check www.hoover.com for more instructions and last time I checked, they had a manual download feature available.
Oct 24, 2007 | Hoover Elite Rewind Bagless Upright...
Vacuums Logo
147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
