We have changed magenta drums in our Xante CL30 three times in the last week. As soon as we change the drum the test sheet prints out fine, works for 500 sheets or so and then a large area of banding starts. We are using toner from Dubber Toner which is economical and has worked fine in the past. The support crew at Xante has not been helpful. Any ideas how we can solve this problem as we have rush jobs at this time. Thank you.
  • 4 more comments
  • leap24 Feb 28, 2008
    Hello Paul
    The toner is currently at 50%.
    We already tried shaking the toner from side to side
    but have NOT tried gently shaking the drum from side to side.
    We will try this and get back to you.
    Thanks,
    AJF at leap24
    Thanks, Paul!
    We?ll try these suggestions and I?ll get back to you with more details.
    Best,
    AJF at leap24
  • leap24 Feb 29, 2008
    Hi, Paul
    My husband has tried all your suggestions but so far no luck.
    We are using refill toner, but we have used this particular
    brand for 6 months with absolutely no problems and we have
    been doing a lot of work.
    Have more rush jobs in the next few days so let me
    know if you have any other suggestions.
    Best,
    AJF at leap24
    Hi, Paul
    We have been refilling original toner cartridge several times.
    We don?t have another margenta cartridge here at the present moment so we will
    have to purchase this (takes several days) to try this.
    Drum does not have any leakage or spillage. We have replaced
    the drum several times this week. Each time we replace it
    it works for about 500-1000 sheets then starts banding on
    1/2 the sheet or more.
    We are out at meetings for the next few hours
    and will check back this afternoon.
    Thanks for all your help,
    AJF at leap 24
  • leap24 Mar 03, 2008
    Hi, Paul
    Thank you for your assistance.
    We received a second (or third?) new drum from Xante
    on Friday. At the moment it appears that the two drums we
    were sent previously were defective. This third drum
    appears OK.
    We have had no problems with the toner we are purchasing from
    Dubber Toner.
    Do you know of a supplier who supplies the empty toner cartridges at a good price?
    Thank you,
    AJF at leap24
  • leap24 Mar 05, 2008
    Thanks for all your assistance, Paul.
    My husband says he does not see any flag on the side
    of the cartridge.
    Our machine seems to be working fine at the moment.
    It seems that Xante sent us two defective drums
    in a row. They should be reimbursing us about $500.00.
    We have kept a record of all your troubleshooting suggestions
    and I am sure they will help in the future.
    Best,
    AJF at leap24
  • 4,102 Answers
Hi do you know when you get the problem is it when the toner is low or is the problem their when the toner is full let me know ok
Posted on Feb 28, 2008
  • 11 more comments
  • paul proctor Feb 28, 2008
    Also if this problems starts after the toner low then take out the drum then give it gentle shake side to side then try printing again let me know the outcome of this ok
    Also try this to reset drum counter sometimes makes a difference but let me know ok.
    1 turn printer off
    2 turn on whilst holding down menu button ( should say user maintenance)
    3 press menu button 3 times
    4 press enter key then the system should go back on line if not then press online key
    let me know if this works on your model should do though
    Also are you refilling toner?
    Also if you are refilling just beware you cant refill the original one as you will always have problems let me know if this is the case or if you are just replacing them
    Hi just thought i mention time here in uk is 23:03 i have to leave now for work but will be back online at 09:00 uk time in 10 hours hope this is no problem just let me know how you get on and ill get back to you then ok
  • paul proctor Feb 29, 2008
    Hi im back online now let me know how you got on ok
    Hi are you refilling the original one or refilling a generic one as ive been told you will keep having problems if you refill the original toner i think it has a flag on the side of cartridge check this as this could be your problem
    And also its best to replace the cartridge after filling up so many times as this will also cause problems so maybe try new cartridge and see if problem remains you might find that this solves your problem.
    And is the drum clean nothing has spilled or leaked onto it causing your problem just going out for 2 hours now shopping but back online then will assist you further then hope this not a problem but my partner cant drive so i have to.
    I will come strait back to you when im back just check what ive said and get back to me ok
  • paul proctor Mar 03, 2008
    Hi sorry but been offline for a while from my experiance and from what other users of your unit have found is that if you are refilling the original toners then you will keep having the problem your having and also as you have refilled that one a few times its best to replace it anyway as they do tend to cause problems the more you refill them.
    I would suggest replacing and then give it a try printing you should find this solving your problem if not give me a shout but you should be fine so get back to me once you have tried this but hopefully youll tell me problem solved
  • paul proctor Mar 04, 2008
    Hi sorry been away for while will ask around for you and let you know soon if the cartridge your filling up doesnt have a small flag on one of the sides then you should be ok let me know if it does have a smaill flag on one side as this cartridge isnt refillable and will cause problems as i live in uk the prices might vary some what so what part of the world you from then i can give you the best price from where you are.
    Fingers crossed problem solved hope you have no more problems
  • paul proctor Mar 05, 2008
    If the cartridge your filling dont have a flag on one side then you can keep using it but if you start to get ant smudges or smears or bad printing then you will need to clean it using alcahol cleaner or thiners type product but you should have no problems now anyway.
    hi no worries just keep the site in mind for all your technical problems hope you get your money back soon also couldnt you claim from them for damages to any printing you have done maybe get some free cartridges as well for the hassle you never know your luck worth a try it was their fault after all and remember if theirs blame their a claim so its goto be worth a try any glad to offer my assistance any troubles give us a shout ok
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
Aug 22, 2012 | Xante CL30 HSE Laser Printer
Printing just fine in black, all of a sudden I am getting streaks across the top of my paper. Then it will stop. After about a 100 or so it will start again. Does anyone know if you change the mono type to...
Yes in the Iqueue advance printing part click it from color to mona and remove the cyan magenta and yellow drums and that will prevent the black toner for hitting the drums and marking before it gets to the fuser
Oct 18, 2011 | Xante Ilumina Digital Color Press Printer
Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Feb 13, 2009 | Xante CL30 HSE Laser Printer
Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
May 02, 2008 | Xante CL30 HSE Laser Printer
CL30 color banding
Banding is often caused by light shock to the drums, caused when the printer is left open too long. This may cause permanent drum sensitivity that will not go away until you instal new drums. You may also find that the banding goes away after you get into a longer run, if it is just the "parked" position of the drums giving you a bad "first copy"
Nov 05, 2007 | Xante CL30 HSE Laser Printer
Xante CL30 printing streak line in middle of the paper
make sure there is nothing on th belt of the unit
Oct 25, 2007 | Xante CL30 HSE Laser Printer
Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
