RE: Sana 4 GB Scan Disk
My computer wont recognize my sana 4gb scan disk. A friend gave it to my and he can't find the instructions but said I need to download something to put my own music on it and I canat get my music transferred to his device from media player it keeps telling me to close or get web help so HELP!!! I did manage to put 4 songs on there problem.. It was a fluk I don't even know how I did it. Sydni
  • 1 more comment
  • kre31 Mar 13, 2008
    My Sony Walkman all of a sudden will not allow the music to be transferrred to it. It will attempt it. I use the RealPlayer because my computer is too old for the windows media player 11. The disk info would not download, so I have been using Real Player/Rhapsody. It was working fine for the past 2 months. I have 200 plus songs loaded, but all of a sudden nothing will transfer.
  • Anonymous Mar 15, 2008
    computer does not recognnize sansa c240. requires conversion to msd (?)
    what should be done to solve the problem
  • shara3 Nov 03, 2008
    My computer won't reconize my 4GB scan disc.
SOURCE: sansa e130
ok, for everyone with e130 "keeps getting an I/O device error, only language screen, than something about 4MB memory..." problem, I just spend six hours of my life trying to solve it and fix my dad's e130 and I succeeded ;)
so, step by step, how EXACTLY I did it:
0) my system was windowsXP SP2
1) remove the battery
2) keep holding the menu button and plug in the usb, keep it for a few seconds more, untill the system will tell you it found a stmp3500 and want to install the hardware
3) allow it to reach windows update for that matter and install the drivers
4) now you have new device that is called "Player Recovery Device Class" you can check it in device manager (Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager)
5) and now is time for flushing new firmware...I managed to find two versions of firmware for e130:
1.0.101e - http://www.sandisk-karty.cz/sandisk-katalog/sansa-e100-series-mp3-players/dokumenty/
2.0.0.01e - http://www.sandisk.com/Retail/Default.aspx?CatID=1295
6) I tried both of them in many different combinations and finally one and one only miraculously worked for me and that was the one when
I HAD THE SD CARD IN THE MP3PLAYER, THE PLAYER WAS RECOGNIZED AS "Player Recovery Device Class" BY THE WINXP AND I STARTED EUROPIAN sansa-2.0.0.01e.exe !
PS: i don't think that there's a big difference between europian and american version of firmware I mention it just to be accurate about the situation. and big thanks to anonymous guy who turned me to right direction with stmp3500. hope that help to others ;]
Posted on Nov 28, 2007
GazllFixIt
  • 103 Answers
SOURCE: MP3 Player Scan DIsk
Yes, you can, although using Window Media Player to transfer/sync is very slow. It is essential to use Windows Media Player if you want to transfer licenced .wma files but it is quicker to just drag & drop the files in Windows.
(.wma files are like mp3s but use a different encoding method)
If you are happy to take the slow route using WMP, (or you need to use WMP to transfer .wma files) then connect your player to the computer by USB, open WMP & click "Sync". Your player should show & you can add files to it in this window.
For quicker file transfer, just locate your connected mp3 player (Start/MyComputer) then copy & paste, or drag & drop files or folders onto it.
Hope this helps!
Posted on Jan 08, 2008
ladydarkness
SOURCE: sansa media converter
hmm, what program are you using? It may be outdated or need to be upgraded or something.
Posted on Apr 28, 2008
  • 4 Answers
SOURCE: Computer doesn't recognize MP3 player -
I had the same problem, all you have to do is first turn on the Mp3.Then go to settings. Then go down to USB mode. It will probably say, auto detect.But instead scroll down to MSC. If that doesn't work try MTP.
Posted on Jul 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sana Clip
mp4 - no
press F5 in windows media player to refresh
Posted on Aug 14, 2008
I HAVE SANDISK MICRO SD CARD OF 4 GB .I PUT IT INTO MY CARD SLOT IT SHOWS YOU NEED TO FORMAT DISK IN DRIVE F:
click start control panel administrate tools computer management disk management right click on your 4gb micro drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Oct 15, 2012 | SanDisk 4GB microSD High Capacity Memory...
Cruzer scan disk can not be recognized by pc
if not recognized or virus attacked your flash disk, just reformat it. but beware you will lose all your files when reformating.
Dec 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My kingston 2 gb flash disk is not recognized, how can i fix it?
Please follow the below steps to fix your problem
Connect your flash drive to your computer using an available USB port. If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double-clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive. A question mark icon should be shown to the left of the label. Right-click the device name and select "Uninstall."
5
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes." This will scan your PC for any new devices. Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
6
Click "Start" > "My Computer" and look for your flash drive. If this process was successful, your flash drive should now show up under My Computer as a storage disk.
Hope the above information will be helpful to you.
Thanks.
Oct 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Need to formatt
Go to radioshack they have a USB card reader for $20.00 that will scan 52 variations. Just plug it in your USB port and you are good to go. The reason your computer will not do it is because it cannot handle a 4GB card. Use a two GB and you should be good.
Jul 27, 2010 | SanDisk 4GB microSDHC Memory Card
Paano mag download ng specialforce d2 sa computer
Hi!
Here is the link, http://sf.ph.gameclub.com/download/sub_gamedown.asp
Just click it, and it will lead you directly to Special Force download site in the Philippines. Scroll down and click Download full version.
Download also cumulative and manual patch. After downloading install on your computer.
That's it!
Sana makatulong to sau. Filipino din ako. Sana matulungan mo din ako. Rate mo sana tong help ko.
Thank you for using Fixya.
Jun 26, 2010 | 10 10 Computer Millennium G200 (8 MB)...
My computer recognizes that I have 1.8 GB left on the disk but when I try to download songs it claims that the disk if full. What do I do?
Good day sir/maam, hi, your SD card may be infected by a virus that wont allow anymore software or files to be stored on the disk, run a virus scan on your PC, there is an easy way to check if your PC is infected, to check, on the my computer menu bar click tools, folder options, view, select show hidden files and folder, then apply, close the window, Now go back to the folder option, view and check the show hidden files, its changed. and goes back to not show hidden files. If this happens, download AVG anti virus and scan your computer.
Nov 17, 2009 | SanDisk 2GB microSD Memory Card
Amazing Pendrive problem
when its loaded into the memory card slot or however you have it attached to your computer right click on the assigned driver letter --> properties --> tools --> scan disk or check disk and see if it comes up with any issues
Also if this is a new memory card get a replacement that or if its too old then buy a new one
Apr 29, 2009 | Kingston 4GB Secure Digital High Capacity...
Reformat 8GB micro scan disk for blackberry.
Try this: "options" then "media Card." Once inside the "media card" section, hit the function key (I suspect this is where you couldn't select the option) and select "format card."
Jan 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
Will a Kingston 4 GB HC card work in this camera?
I just put a Scan Disk 4GB HC card in my D40 last night. The card said it would only work in devices made for HC. It seems to work fine.
Dec 05, 2008 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Usb not recognized when I put scan disk in port
do 1 thing plug it on a other PC or on a mac and see what happens !!
then format the volume..
hope this helped...!!
Feb 28, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
143 people viewed this question
 Grubhead
Grubhead
