I want to install the new 2gb myself into my compac desktop
I need to find out how to install my memory upgrade
    Genius:
  • 3,587 Answers
Good show...however, one might want to know what computer model you're dealing with, no?
can you tell us the computer model, please?
Posted on Feb 28, 2008
    Novelist:
  • 155 Answers
Installing memory couldn't be easier! (Just make sure you have the right sort for you particular computer)
Turn off computer and UNPLUG from mains.
Open the case to expose the motherboard.
(Ideally, before you do anything else you should make sure you are wearing an earthing wristband to prevent any possible damage to your PC from static discharge. Having said that, I've changed loads of memory in the past without wearing one and have never had a problem, but you have been warned!)
Locate the slots that your memory goes into - This will be fairly easy because they won't fit into anything else! Insert the memory cards and make sure they are fully locked home.
Put the case back on, plug it in and turn it on.
And that is it! Simple! The PC will automatically recognise the new memory - There are no settings that you need to change.
Matt.
How to upgrade the video card?
You will have to add a new card to the motherboard. Open the cover and insert the new card in a slot and close the cover. Run Windows. Run the driver CD of the new card to install the drivers . From Control Panel->System->HW->Device Manager select the old card and disable it. Also check if the new card shows. Reboot the computer and connect the video cable to the new card. Your new card is functional now. Go to Control Panel->Display->Settings and configure Colors and Resolution of the new card.
Jul 06, 2011 | HEWLETT-PACKARD Pavilion Slimline s5304y...
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
Can I do a memory upgrade on Sony VGC -LS 37E?
the specs for your computer, it states that it is equipped with 2gb of memory 2x1gb and max at 2gb, so I doubt that any higher memory upgrade installed would work, or else it would cause your system to crash or even damage it.
Jan 24, 2011 | Sony VAIO® VGC-LS37E PC Desktop
I am try to upgrade the memory in my W3115 from
The bios has nothing to do with memory,
What memory did you have installed, what moder;llkl'j wqpwrl #
Feb 08, 2010 | E-Machines eMachines Desktop PC
I want to upgrade the standard 512mb RAM to 2GB. once installed do I just restart the computer or do I need to do something to allow the computer to recognize the new RAM?
You should be fine to just turn the computer on straight away as soon as you have installed your new RAM. The computer will recognize the new upgrade straight away provided you have got memory that is compatible with the desktop computer.
When you upgrade the RAM take the old RAM out and make sure your new RAM runs at the same speed as your old RAM.
From what i can remember the maximum RAM speed that an HP pavilion supports is 400MHz although it could well be 333MHz.
The RAM that's installed in the desktop at this moment in time will have the speed on it so you check with that.
Regards.
Jan 25, 2010 | HP Pavilion a450n PC Desktop
Gateway 500x upgrade ram installation.
hi! there if your addibg a memory card check your memory speed if match to other memory card that are installed already,they should have same speed e.g DDR PC228 or SDR PC333 so check this out before installing.But if you replace the older one upgrading,switch off your computer open cover,there is slot there for your memory card bedide your processor,at both end there a lockway,unlock your memory card and pull it out all if you have several one,then insert on one slot if that is one memory card at 2gb lock it on both end.then swich on your computer check this out on your computer properties if there is change.how to do this left click my computer,click properties.regards
Mar 27, 2009 | Gateway Computers & Internet
Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Jan 28, 2009 | eMachines W3507 PC Desktop
Trying to upgrade RAM - won't boot after new RAM installed
Install the RAM on memory slot and Switch on your system and go to BIOS settings. There you can check whether your RAM is working properly or not. If it shows no memory installed then the RAM Chip may be damaged.
Jan 08, 2009 | E-Machines T6520 PC Desktop
Computers & Internet Logo
117 people viewed this question
Alun Cox
David Payne
David Payne
