Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Memory stick not recognised
I added new 4GB extn memory stick in player but its does not show in any where neither in player nor in PC.
    Genius:
  • 1,019 Answers
You Need To Format The Memory card.
Should show up As A Drive In MyComputer/F:/G/H/I
Right Click And Properties.
Then Format The Stick.
Cool as A Cucumber.
Mike @ Compurepair.
Posted on Feb 28, 2008
Computer doesn't recognise memory stick pro duo 4gb
Hello Guys,
The computer sometimes doesn't recognize the memory stick device due to corruption, there are numerous causes for memory stick corruption for example virus attack, improper removal, wrong usage of the memory stick device and many more. After such corruption scenario data are lost from these devices, but luckily you can recover memory stick files by using an efficient recovery application like Yodot Photo Recovery. Apart from memory stick the tool also recovers files from all other devices like memory stick, hard disk, iPods, music players etc. Try using this tool to recover your data from memory stick
Aug 20, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
I recently added 2 sticks of 1 Gb Ram to my desktop, to now have a total of 4 1 Gb sticks. This newly added memory is PC2 @ 5300Mhz speed. The older 2 sticks of 1 Gb memory are PC 2 @ 6400 speed,...
It depends on what you would like the end result to be. If you need to multi-task, and have 10 windows running at once, go with the 4GB @ 5300 because while it might take a little longer your computer will still be able to handle all the information. However if you are just using it for light browsing and would prefer speed over bulk (when it comes to data processing) go with the 2 @ 6400. I don't think it would be worth it to get 2 more @ 6400, technology is advancing so fast. If you have 60 bucks you can upgrade to two 4GB @ 10600 (8GB total for $60) 1333MHz PC3. Lookup Corsair XMS3 4GB RAM.
Jul 29, 2011 | ASUS Computers & Internet
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
Asus 4 GB
windows xp will not show 4 gb of memory, it will support it but not show. you would need vista 64 bit to be shown the full 4gb of memory
Mar 16, 2009 | ASUS Eee PC 4GB Notebook
Added new ram stick now monitor does not recognise pc tower
According to this page (a memory vendor which I'm using only for illustrative purposes) your machine only supports up to 1gb sticks of the 400mhz variety. So you would use 4 x 1gb for a total of 4gb max.
Feb 21, 2009 | E-Machines T6528 PC Desktop
Acer Aspire 3690-2970 Memory Upgrade
Your laptop may just not recognize and not even boot up if you exceed the memory limit. It will not harm the laptop if you give it a try with the 4gb. However, sometimes caution is a good thing. It all depends on what you are trying to do on your acer. If you haven't already, remove the old memory sticks and replace it with the 1 2gb memory stick. Work with it for a little while (this should not give you a problem). If you feel the laptop is still too slow....let me know...I will look up the compatibility with the memory and your laptop.
Nov 16, 2008 | Acer Aspire 3690-2196 Notebook
Memory Stick Pro Duo 8GB on PsP
Two possibilities.
1. The firmware on your PSP is too old to recognise the 8GB (only recognises up to 4GB).
2. If firmware is up to date you have a fake memory stick (easy way to check is to check the info for the memory stick on your PSP if its says that MAGIC GATE is unknown rather than supported then it is fake.
The fake ones typically double compress the data so that it appears to have 8GB when in reality it does not.
Nov 15, 2008 | Sony Memory Stick PRO Duo (2GB) for PSP
Psp wont recognise my sony 4gb memory stick pro
put a thin sticker on the opposite side of the golden pins and try again
Sep 24, 2008 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick not identified.
The memory stick probably is not the right type. The Sansa only takes SD Micro chips. However, IIRC Micro only goes up to 2GB. So, if you have a 4GB chip is must be a SD HC (High Capacity). Unfortunately, these do not work in the Sansa.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
