Question about Brother MFC-8840D All-In-One Laser Printer
CHECK ORIGNAL WHEN I AM TRYING TO FAX THE PAPER, I AM GETTING THE MASSAGE "CHECK ORIGINAL" AND I ALSO FIND LEFT SIDE HINGES ARE BROKEN
  • Anonymous Sep 29, 2008
    check original
  • 106 Answers
You have the problem with your adf on machine try to see where is sensor jammed or broken
Posted on Feb 28, 2008
Check document error, no paper jam
It may be a bad hinge on the document feeder. I have seen several times where the left hinge ( when looking at machine from front) does not close all the way. Close the adf and look at the gap between the copier and the adf. The gap should be the same from the front to the back. If the gap is bigger at the rear ( when looking at the left side of the machine) then you need to replace the left hinge. You can also try pushing down on the document feeders' left side as it feeds the paper. if it works while pushing down, then it is the hinge.
Sep 05, 2012 | Canon Imagerunner 1025n
Faxing
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Paper sticks half way when I try to FAx
Probably the left hinge is broken not letting the adf cover go all the way down and causing jams. A new hinge is #LP2403001, around $15 to$18.00
Aug 20, 2009 | Brother MFC-8440 All-In-One Laser Printer
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Canon faxphone l75 doesn't print or receive fax
What became of this? Our fax is having the same problem. We are getting no help from Cannon
Feb 23, 2009 | Canon FaxPhone L75 Plain Paper Laser
Brother mfc 8440
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Sep 03, 2008 | Brother MFC8440 Remanufactured Laser...
Can't make a copy
1: power off and power back on. 2: see the original manual for resetting to factory defaults.
May 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
199 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
