Question about Acer Aspire 5315 Notebook
Overheat will my acer laptop get overheated or be damaged if i stay on it allday?
  • Anonymous Mar 24, 2008
    fan keeps turning off when booted
  • Anonymous Sep 16, 2008
    yes my daughter and i both have these laptops and had problems excatly the same must b a commom fault.
    Genius:
  • 1,019 Answers
Sure it Will,
If you keep running for 24 hours, how Would you feel ??
If you need to run your computer for long periods, keep by a well ventilated area ( slightly open Window ) for extra Cooling.
If you Have legs on the underside, open them up, so that the laptop is off the Desktop. ( air circulation Underneath )
Place on a solid surface ( wooden top et,c )
Make sure nothing can interefere With Outlet ports. ( Fan Blower )
But In general Not recommended.
Thankyou For Using Fixya :)
Mike :@ Compurepair.
Posted on Feb 28, 2008
    Problem Solver:
  • 28 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 19, 2010
    Problem Solver:
  • 28 Answers
Hi Friends,
Problem with
Your problem could be about ePower Management program which is preinstall by Acer. It has no sense but if you don´t run this application, after sleep mode (or hibernation in some cases) the fun won´t work again. Acer won´t fix it because their don´t considere it a problem!!!
Posted on Aug 20, 2008
Toshiba Tecra S2 & S4 experience:
Symptoms: sudden total unexpected shut-downs
temperature external casing under cooling module: 63 - 65 degrees C.
Solution: strong vacuum cleaner suction tube applied for couple minutes to cooling module fan exhaust port - to suck out all dust!
Result: equilibrium temperature - even after 12 hours continuous use is 35 - 40 degrees
See also: http://www.laptoprepair101.com/laptop/2006/01/04/toshiba-laptop-overheating/comment-page-33/
This makes sense.
Regards = John
Posted on Jun 30, 2008
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
Notebook demonteren
==== http://www.proxy4biz.com ==== ====accept credit card and paypal
Cheap Nike air Jordan shoes33$,Air Force 1 33$, Nike dunks SB shoe,Nike Shox shoe. Wholesale Cheap Nike shoes with discount jersey, High quality T-shirts,ED hardy t-shirts,ED Hardy hoodies,ED hardy shoes,ED hardy Jeans,Evisu shoes,GUCCI shoes,LV Handbag,Chanel Handbag......welcome to====http://www.proxy4biz.com ====
Nike shox(R4,NZ,OZ,TL1,TL2,TL3) $35
Handbags(Coach lv fendi d&g) $35
Tshirts (Polo ,ed hardy,lacoste) $13
Jean(True Religion,ed hardy,coogi) $30
Sunglasses(Oakey,coach,gucci,Armaini) $15
New era cap $16
Bikini (Ed hardy,polo) $18
Oct 04, 2011 | Acer eMachines 520-2890 Notebook
Have acer one notebook. cant restore even with restore disk. a friend bought one at the same time june 2009. acer customer support said there is nothing they can without sending in for repair. did check...
You won't physically see damage from heat. It is the CPU and motherboard that gets damaged when it overheats. If they did a recall they might cover replacement even though it is several years old now. You might want to ask them.
Feb 19, 2011 | Acer Aspire One PC Notebook
I have an acer 5520 laptop,it has started shutting of without any warning even though plugged in and fully charged
Causes:
1. Overheat
Most cases this is caused by a over heat where the system fan gets blocked or there is not enought air flow, this can damage the system cpu.
Other known causes
AC/ adapter needs to be replaced some case were found that the ac adapter would be the cause as well it would be something to have checked out.
Now if the system shuts off without the ac adapter and its running on the battery as well you might want to look at the overheat issue.
thanks for using fixya please do be considerate and post you ratings and feedback for your answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2010 | Acer Aspire 5520-5908 Notebook
I have a dell D600 sometimes the top 1/4 of the
I think you may first format the notebook , if it works its ok or otherwise your screen is damaged , change it
May 20, 2010 | Acer Aspire One PC Notebook
Laptop shuts down at random times it sometime shut dowm within 5 minutes i use or can stay on allday but now it shuts down within like 20 minutes of use.please help
I THINK ANY VIRUS MAY BE IN YOUR SYSTEM. PLEASE FULL SCAN YOUR COMPUTER THROUGH A GOOD ANTIVIRUS. IF PROBLEM REMAINS SAME THEN YOU HAVE TO CHOOSE FORMAT WINDOW AND THEN REINSTALL WINDOW.
Sep 30, 2009 | Sony VAIO VGN-AR630E Notebook
Acer one AOA 150-1786 running Windows XP SP3 Home Ed.
Those signs are those of a dead motherboard, it is quite expensive to fix i would recommend to replace it with your dealer
Jun 15, 2009 | Acer Aspire One Netbook 8.9" Notebook
Keyboard and mouse pad on my laptop. Acer 5100 vista
On an Acer, the Fn key plus F7 will turn the touchpad on and off.
Try that to see if it works.
Mar 22, 2009 | Acer Aspire 5100 Notebook
Tecniical diffacultyes
Ive had the same problem with one of my laptops and i found out that sometimes the computer wont start because the cooling fan wont work u see when the cooling fan is broken theres something in the computer a magnet of somesort that wont let it boot because it will overheat if stayed on too long this might not be the problem but if it is i would take t to a computer place and have them fix it before it overheats or put one in urself and get on off google just type in acer 5100 cooling fans if u have experience with computers hope this helps noah
Jan 18, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5315 Notebook Logo
240 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
