Question about Canon LBP 1120 Laser Printer
Service error When i power the printer the motor attempts to roll but it stops immediately.When i attempt to print there is a display of SERVICE ERROR. What do u think is happening to my printer.
    Problem Solver:
Hi, I have a canon 1120 printer the problem is:when I turn on the printer, the motor should be run for a while, but the motor doesnot run at all,but the power LED is on,I dont Know what is the problem,help me please?
Posted on May 03, 2008
  • ghasaq80 Sep 21, 2011
    have same trouble
Hp 500ps severe error code Ox40d0003-
If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
    NOTE: Always verify the printer's current Firmware release and upgrade as needed.
    1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
    2. If the error appears or problems persist, continue with the remaining steps.
    3. Turn the printer off, and disconnect the power cable.
    4. Remove the right end cover.
    5. Check both Ink Supply Station connections on the Interconnect PCA. If the unit shows the error on boot up verify that the connector with the blue wires is seated correctly (Connector P4). If the error appears when a print job is sent to it verify that the connector with the red, black and green wires is seated correctly (Connector P2).
    6. Reconnect the power cable and turn the printer on.
    7. If no error appears, attempt to verify functionality.
    8. If the problem persists, continue with the remaining steps.
    9. Replace the Ink Supply Station (refer to pg. 8-48 of the HP Designjet 500 and 800 Series Service Manual).
    10. Following replacement, attempt to verify functionality.
    11. If the error reappears, replace the Electronics module (refer to pg. 8-24 of the HP Designjet 500 and 800 Series Service Manual).
Jan 02, 2017 | HP DesignJet 500ps (42 in.) InkJet Printer
My hp office jet all in one printer is only displaying error ,when i turn it on
HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
A 'Paper Jam' Error Displays on the HP Officejet 4215 a
Dec 18, 2015 | HP Office Equipment & Supplies
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
My canon has an error b200 and it doesn't print or do anything I command.
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Nov 02, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Can't print on Photosmart 3110 all in one
This is a result in a print head failure or the use of non HP ink ether or there right you need to service the unit part will be needed if the maintance does fail. If your using non HP ink stop its use and purchase HP ink you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | HP Photosmart 3310 Printer
Canon i455 printer displays canon service error 5C00
paper mechanism is vey suspect - time for a new one
Jul 18, 2009 | Canon BubleJet i965 InkJet Printer
Service error 49.4c02
found this on hp forums try and see if works for you to.
"Try unhooking the printer from the computer. Turn the printer off then back on. and when the memory starts counting up hold the check button until the three light below turn on then release. then arrow down to cold reset and hit the check mark and see if you get past the 49 error"
Jun 17, 2009 | HP Office Equipment & Supplies
Canon i860 - Service Error 5100 I have tried the reset procedure several times (Resume, then power and hold power, resume 2x, release power) but the light never stops blinking to go on. Any...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME (while still holding down the POWER)
3. press RESUME twice, then release POWER
4. The green light will blink and the printer will make some noise. Wait until this is finished, you are now in the printer's diagnostic mode.
To select one of the functions below, use the RESUME button and then press POWER to execute:
# of RESUME Presses - Light Color - Function
0 - green - Power Off
1 - orange - Service Test Print: Extended nozzle check pattern
2 - green - EEPROM information print
3 - orange - EEPROM initialize
4 - green - reset waste ink counter (For the Canon waste tank full error)
Remember... ATTEMPT THIS AT YOUR OWN RISK!!!
May 03, 2008 | Office Equipment & Supplies
Canon LBP 1120 Laser Printer Logo
292 people viewed this question
old marine
old marine
