Question about HHB 830 Plus CD Recorder CD Player
HHB-830 CD TRAY does NOT open.
Unit powers on and all functions are in order. When OPEN button is pressed display screen flashes OPEN then reads CD? > CDR? > as if a disk were loaded into it, but the tray never opened to load & feed. Any suggestions or a LIST of Authorized Service Centers would be greatly appreciated. Local Pro Audio Shops (San Diego) won't touch HHB's.
  • dereklb Feb 05, 2009
    I have a similar problem on the 850 model. Does this procedure also apply to this machine? Also could you email a copy of service manual. Many thanks
  • 112 Answers
It's made for HHB by Pioneer, you could try one of their agents?. Opening up is fairly straightforward if you are methodical and take your time if you need to. There is a test mode sequence you can try - hold down the 'menu/delete' and 'auto/manual' keys together for 5 seconds until the display blinks all the lights then press the stop button. Now ONLY press the open / close button - pressing any other keys will change settings and without the service manual you won't know what you're changing. Press stop then power it off to exit.
I can email you the service manual if you need it. It sounds like a gear has come loose inside to me. I strip these machines for parts quite regularly so may be able to help you out if you're able to work out what if anything is broken but I'm in the UK. It may be as simple as a belt has come loose :-)
Posted on Feb 29, 2008
My dvd is not working on my blue ray it saying go to update some software
you will need to download the update from
http://pages.samsung.com/us/bluraysupport/support.html
how to - make an update CD
  1. Download the software update file for your hardware.
  2. If the update is compressed (zip file or rar file), the file should be uncompressed before burning.
  3. You must burn the update file on a blank CD-R/W disc by using "Burn Image" option.
  4. Burn an image file of the software update file (*.iso)
how to - update your player with your CD
  1. Press OPEN/CLOSE to open the disc tray.
  2. Insert the update CD-R disc with the software update, label facing up.
  3. Press OPEN/CLOSE to close the disc tray.
  4. Wait 1-2 minutes until the screen displays "Verifying Firmware version..."
  5. After checking old and new version, select "Yes" or "No" with "?" or "?"
    on the remote control. If you select "No", BD-P1200 will be powered off in a state of tray open.
  6. Press ENTER button on the remote control.
  7. Remove the update CD from the tray.
  8. Screen will display "Firmware Update Now Processing... Please do not turn off the power".
    This process will take 4-5 minutes. When done the screen and power will turn off automatically.
  9. Turn the unit on again with the power button. They tray will close automatically and a
    Menu Language Selection screen will open.
  10. Select the Language you want by pressing the corresponding number button.
  11. Update is complete.
Jan 15, 2011 | Samsung BD-P1500 Blu-Ray Player
What does pma rec mean on the hhb cbr 830 ? it just stops recording
The recorder is writing TOC data to the disc's PMA (Program Memory Area). Never turn off the power while this display is
showing.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
Aug 13, 2010 | HHB BurnIt CDR830 CD Recorder
Cd ejection tray
From Standby press function, whilst holding function press power (both on the main unit).
The display will show demo mode, this has now disabled the mode.
Regards Graham
Jul 25, 2010 | Denon D-M33 Shelf System
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
HHB 850 CD Burner - lockup problem
I did find out how to do the manual eject, for a stuck cd. Open up the machine, looking at the front/top, on the lower left side of the cd transport there is a white plastic gear that can be turned with your finger, ejecting the cd.
Oct 30, 2007 | HHB CDR850 CD Recorder
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
HHB 830 Plus CD Recorder CD Player Logo
239 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
