Question about Sharp AR-153E Copier
AR-157E intermitent dark background through SPF on AE only
Have 2- AR-153Es that have intermitent dark bckgnd through SPF on Auto exp only...Text mode through spf is always fine...All supplies are up to date...Have changed exp settings in tech mode for SPF and copies look great in this tech mode but as soon as i go back to regular operations mode it has a slight haze background with text looking light (almost like it is in toner save mode but its not) and it is only through SPF in Auto exp when the problem occurs, any help out there?
  • 62 Answers
Change code 46-19-1 from2 to1 .
Posted on Mar 23, 2008
  • 4 Answers
Check the white patch
Posted on Feb 28, 2008
Sharp 157e H4 blinking,where is the fuse and or thermostat to check. This Church copier is 6 years old and paying a technician several hundred dollars to come out to fix it is crazy. Do you have any...
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
Aug 09, 2011 | Sharp AR-157E Copier
I am needing to download the software for my Sharp Digital Imager. The model is AR-157E. Is there a place on the website for this? I am having problems locating this.
You can probably get them from cnet.com. They have most all drivers for the last several years. They also have a lot of other software downloads.
May 17, 2011 | Sharp AR-157E Copier
I have a very dark line down the side of my copies
Have you chaged the drum unit recently? You may want to try cleaning the main charge unit in the drum.
May 07, 2010 | Sharp AR-157E Copier
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
How much is a used Sharp AR-157E copier worth (in good working condition and about 5 years old)?
If him to do get prettier preventive maintenance and put(deliver) the new grosses a photo and teflon, new starter, rollers of the seizure of the paper, $500 possible offer, able gross without change not more 100. My opinion such, do not interest the devices old, only if cheaply. The Expenseses on their reconstruction dispense vastly and preferred to take new, either as car. Solve
Sep 23, 2009 | Sharp AR-157E Copier
Can you bypass a low toner alarm on a AR 157E to allow the unit to run paper through the paper path
Yes in service mode. But you will not make a copy with out any toner in the copier.....
May 06, 2009 | Sharp AR-157E Copier
AR-157E blank page when using automatic feeder.
you night check to see if your cable to the copier is connected but this problen iv seen several times not worth fixing the main pcb is usally gone as for as working with the feedder
Feb 17, 2009 | Sharp AR-157E Copier
Sharp AR-153E Copier Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
